Old 02-22-2010, 08:42 AM
Jasonsansfleece Jasonsansfleece is offline
Rep: 10 Posts: 19
Centerboard Trailing Edge
Hi,
I am going to build a wooden cored dinghy centerboard covered in 10oz boat cloth.
I have made four other foils of various size using similar methods.
This board calls for a very fine trailing edge.
The angle between the sides of the board at the trailing edge is 20 degrees and taken out to a fine 1/16"
I have previously faired the wooden edge as fine as practical then drawn the cloth together at the trailing edge so they over lap beyond the core. Trim and fair.
Is there a better way?
I imagine truncating the faired wooden edge and building it up with a filled epoxy. But if the density of the filler is much higher than that of the wood (mahogany) then there will be issues with sanding.
The reason I ask is my concern over the strength of the trailing edge,
Thanks,
Guy
Old 02-22-2010, 11:22 AM
Hunter25 Hunter25 is offline
Rep: 46 Posts: 173
A trick I have seen used is to cut a groove and fit an aluminum strip on edge into it. You could build up an epoxy edge maybe using Mylar sheets to keep fairing down. A centerboard trailing edge is pretty safe from damage, but a daggerboard is just the opposite needing a really tough trailing edge.
Old 02-22-2010, 12:59 PM
Rep: 1493 Posts: 7,447
If you are using true mahogany, it is hard enough that it shouldn't be a problem
Old 02-22-2010, 01:56 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
I used a sailbatten, instead of a wooden or alu strip. Worked fine every time.
Old 02-23-2010, 12:26 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
This is similar to what we used to do & clever for a strait edge, alternatively we used to drape one side & let cure & then lay uni fibre in the edge, sand flat & drape the other side. All the best from Jeff.
Old 02-23-2010, 01:17 AM
mark775
Funny that the aluminum came up as I just finished fairing my keel to a knife edge, chickened out and rounded it to 1/8" radius. It worked very well to simply leave the heavy fabric an inch long, sawzall it to a quarter-inch long when cured (with poly one could green-knife) and sand to an edge that would cut you. Fine fabric or cloth would be a little floppy to control. I ran a bead of neat epoxy down from the top to insure no holidays, then closed up, rolled, and touched up a little off-center crookedness by (gloved) hand. Now I'm kickin' myself for not putting a piece of metal stock in there...
Old 02-23-2010, 03:27 PM
wet feet wet feet is offline
Rep: 99 Posts: 264
I have had success by vacuum bagging the glass sheathing into contact with a strip of Formica laminate and adding an extra strip of glass to add bulk.The Formica strip is around three inches wide and projects half an inch or so.When the resin has cured,I tidy things up and apply a small flat trailing edge.The strip of solid glass has proved to be quite durable.
Old 02-25-2010, 10:45 PM
kflarsh kflarsh is offline
salisbury
hi, I'm new to this forum and not a professional fiberglass repairer but I had a similar challenge 10-15 years ago when i faired a keel on my Sun 34 sloop.I used a strip of aluminum window or door screen neatly cut & held with I think( or can't remember,) spring clamps,(temporary tacks, staples or hot melt glue would suffice also), to which i applied west system epoxy and layers of cloth. The screen, when stretched tight and fastened, provided a very thin , straight, and relatively firm surface to start laying up the cloth and resin . I was able to sand the trailing edge to where it was almost too sharp yet very strong.It still looked flawless when i sold the boat 6 years later!
Old 02-27-2010, 11:58 AM
Rep: 10 Posts: 19
Thanks for the replies!
In this case the trailing edge is a curve in profile which precludes the use of a batten. As Gonzo says, with a mahogany core (as opposed to cedar) it should be strong enough.
Edge molding scotch&water Materials 3 08-25-2009 12:00 PM
best leading edge? lunatic Boat Design 3 11-30-2008 10:14 PM
Squaring the trailing edge of a daggerboard mikereed100 Multihulls 11 08-21-2008 03:49 PM
Edge Marine Outlaw Powerboats 1 12-13-2006 04:47 PM
Non symmetrical trailing edge (rudders) danielro Sailboats 2 03-10-2006 04:52 AM
