Old 04-07-2005, 06:01 AM
henrikb's Avatar
henrikb henrikb is offline
Rep: 116 Posts: 112
Carbon tapes for tabbing?
When tabbing bulkheads (carbon in both hull and bulkheads), do you use woven tapes of 0-90 or +-45 style?
The +-45 would be preferable, but seems really hard to find in width less than 3 inch? To be able to get around curved areas, I am planning to put one (depending on tape weight) layer of tape from each side, with overlap in the fillet area.
What is the common solution to this?
Henrik Borg
Builder of the IMS33 R/C
http://web.telia.com/~u21114029/
Old 04-07-2005, 07:00 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
A 0-90 would be a poor choice for any bonding reason is only half the filament cross over the joint if you can not find tape then cut the tabbing from a roll of +-45s or at a bias from a roll of 0-90
Slippery when wet.
www.cheetahcat.com
Old 04-08-2005, 01:44 AM
henrikb's Avatar
Rep: 116 Posts: 112
As mentioned, thats why I want the +-45
Cutting diagonals from the 380g twill is not easy, really hard to keep it together, I am quite sure that it is not the way the pro's does it?
Henrik Borg
Old 04-08-2005, 04:39 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Henrik,
One trick that can work in certain circumstances is to wet the fabric on a strip of plastic film or some other suitable substrate, then gently peeling the plastic off after you've positioned the reinforcement. You can also wet a larger chunk of fabric on top of plastic and then cut your tapes. I would caution against leaving the edge of the tabbing in the radius, its better to run it across the joint.
Lycka till,
Jocke-butt.
Old 04-08-2005, 03:36 PM
Rep: 84 Posts: 661
Henri ;What are you using to cut it shears ?? If you want a straight cut use an electric cutter..Like the garmet industry uses I have two one a round knife the other a straight knife..
Slippery when wet.
www.cheetahcat.com
Old 04-19-2005, 09:09 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
Use knitted reinforcement, not woven. The stitching in knitted stuff keeps it together quite well. at least enough to position it and wet it out.
Old 04-19-2005, 09:10 PM
John ilett's Avatar
John ilett John ilett is offline
Rep: 23 Posts: 131
I use a narrow glass tape on my dinghies. It is a 0-90 tape but with the majority of the fibre across the roll.
45 deg tapes are nice if you can get it. Buy a whole roll of stiched double bias and have it cut to your preffered width.
Old 04-20-2005, 01:29 AM
henrikb's Avatar
Rep: 116 Posts: 112
Thanks for all ideas!
Tried Yokebutts metod this weekend, worked really nice! Wetted out a large chunk on a piece of plastic, then cut the carbon diagonally together with the plastic. Really easy to fit even in curved areas!
We have a 90kg roll of 0-90, so buying another roll just for tabbing is not an option....
Henrik Borg
e-glass vs. aramid/kevlar vs. carbon JEM Materials 12 06-12-2005 04:19 PM
What is Carbon Carbon? Hypercat Fiberglass and Composite Boat Building 2 05-06-2005 10:13 PM
Carbon mast construction in 2 female 1/2's bjl_sailor Fiberglass and Composite Boat Building 4 05-01-2005 12:30 PM
Corrosion between Al and carbon grob Materials 11 02-18-2005 12:39 PM
carbon monoxide boating deaths Guest Open Discussion: All Things Boats & Boating 7 10-28-2003 09:51 PM
