Old 01-26-2011, 05:06 PM
nickireson nickireson is offline
Rep: 10 Posts: 10
Carbon/Kevlar shaft layup questions
Hey everyone,
Ok, so I am planning on making a few composite handlepoles for stand-up jetskis. I have a few questions though.
The handlepole will be similar to this:
The Black parts will be aluminum, I intend on having some parts machined to handle that part. The composite shafts will fit into the aluminum mounts which in the above image, are represented by the silver aluminum.
So....
Would it be best to use a carbon/kevlar 50/50 blend, or just carbon?
Also, if I use the medium strength sleeve from Soller Composites will 3 layers be adequate? The poles will probably take a lot of abuse, and I want to ensure that they will not fail. Some riders will be in heavy surf, doing backflips, submarines, etc...
Next, there is a product they sell that is a heat shrink tubing that you use after the wet lamination to get a tight layup and squeeze out excess resin.
Is this process even remotely comparable to a vacuum bagging process or not as beneficial as far as added structural integrity?
Many thanks in advance. Also if you have any thoughts or comments about things I didnt mention yet, all input will be welcomed.
Old 01-26-2011, 05:13 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Carbon prepreg ,those are small pieces.
Slippery when wet.
www.cheetahcat.com
Old 01-26-2011, 05:21 PM
Rep: 10 Posts: 10
Im am completely unfamiliar with prepreg composites, its benefits, and even how it works
Old 01-26-2011, 05:35 PM
Rep: 10 Posts: 10
So I did a little looking around. Pre preg is just carbon with resin and hardener already added, and you just bake it? Im not seeing how there would be any difference here?
Old 01-26-2011, 06:07 PM
Rep: 84 Posts: 661
Sir they have taken all the fun out of it, And Yes it is basically a resin and hardener impregnated fabric , But a very sophisticated resin system and the strongest parts imaginable are built from these materials, nothing else is even close.
Slippery when wet.
www.cheetahcat.com
Old 01-26-2011, 06:10 PM
Rep: 10 Posts: 10
I see. I saw a youtube vid about a guy that makes his own pre preg and just freezes it...pretty cool!
Old 01-31-2011, 02:54 PM
cosborne cosborne is offline
Rep: 27 Posts: 5
Just a warning, you don't want to put metals in contact with carbon in a marine environment. You'll need to put a layer of glass between the two.
With that being said, you may not want to use a biaxial sleeve to do this. Also, keep in mind the finish work necessary will be pretty crazy if you don't mold this.
My suggestion as a composites manufacturer with an engineering staff...
Build a mold and infuse it. You'll be able to handle more production, add in the glass, have a beautiful finish and best of all it's faster.
I don't see any benefit to using kevlar. I'd consider doing some engineering if I were you. Otherwise you'll end up making a bunch of parts that don't work. There are also a few companies out there that can do it for a reasonable price and handle the engineering.
Old 01-31-2011, 03:21 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Also, I would integrate as many functions as possible into the part. I would probably skip the aluminium castings / parts and go for a 100% composite part, probably ending up with carbon and perhaps some glass.
Old 01-31-2011, 04:12 PM
Rep: 27 Posts: 5
He makes a good point. If the metal components are not load-bearing then definitely try to eliminate them. It will be quicker and less expensive to infuse the whole thing without those components. If the components are load bearing I would keep them and infuse them into the part with a layer of glass separating them from the carbon. The reason for this is without engineering to determine the loads you don't know how much the carbon will have to take. Metal works great for these situations where you have an undetermined or inconsistent load.
Old 01-31-2011, 04:27 PM
Rep: 10 Posts: 10
Well I am definitely no engineer. I know that (here come the technical terms) the poles take alot of abuse from some pretty heavy riding, but the stock ones are made of simply SMC fiberglass, so it is entirely possible, and maybe even more cost efficient for me to do it, once I have completed the mold making? Since I dont have the experience or money to have the part properly engineered, I will have to use so much carbon that it will be overkill I suppose. What is a basic layup schedule that will be light but almost indestructible?
Old 01-31-2011, 04:40 PM
Rep: 27 Posts: 5
Unfortunately, light and almost indestructible don't go together. The reason most composite products are engineered is that the finite element analysis will show exactly where the loads are. In those areas, you can add foam or remove material altogether.
With all that being said... if you're willing to go out there and potentially break a leg, you may want to try a structural foam 5ish pounds with 4 layers of uni @ 0, +45, -45, 0. Something like this http://www.carbon-fiber.us/12oz-unid...ard-p-993.html
I don't know a lot about your part but that's my best guess. Could be totally off base and I'm sure someone else here can give you some better insight. I have some ebooks and such I can send you if you want to learn about what's involved with the molding since that's your first hurdle.
Old 01-31-2011, 04:43 PM
AndrewK AndrewK is offline
Rep: 338 Posts: 377
Just buy ready made filament wound tubes.
Old 01-31-2011, 04:52 PM
Rep: 10 Posts: 10
I have done some very mild molding before, but would certainly appreciate any knowledge or info you can pass on! One of my favorite things about composites is that there is always always more to learn. How do I get these ebooks?
Old 02-01-2011, 08:00 PM
Rep: 27 Posts: 5
Sorry to leave you hanging there... got busy today. Shoot me a pm or email with your email address and I'll send them over. The main one you should read is pdf format. I think the other one is too but could be word.
Old 02-02-2011, 09:05 PM
Rep: 10 Posts: 10
I guess I cant send private messages yet? Nickireson@hotmail.com
Thanks!
Rudder Post in Carbon or Kevlar nero Multihulls 11 03-10-2009 06:40 AM
Carbon fiber Kevlar hull? Todd D Fiberglass and Composite Boat Building 3 11-27-2008 01:30 AM
Carbon/Kevlar Transom Bullseye Fiberglass and Composite Boat Building 15 06-28-2007 08:16 PM
prepeg carbon/kevlar the_sphincter Materials 1 11-22-2005 04:47 PM
e-glass vs. aramid/kevlar vs. carbon JEM Materials 12 06-12-2005 03:19 PM
