| Cosborne are you still around? |
| Just shot you an email. |
| Hey, You said that there were glass SMC parts similar to this. Perhaps you know the thickness of these parts? If you build up a similar thickness in the earlier mentioned 0, +45, -45, 0 in carbon (and repeat this untill you get the required thickness), you'll probably have a conservative design which is a similar in weight (carbon weighs less than glass, but you'll probably have a higher fiber content) but will work. Nevertheless, I would try to get the aluminium parts out as well. Engineering might be a good solution. Cheers Coen |
| Rudder Post in Carbon or Kevlar | nero | Multihulls | 11 | 03-10-2009 06:40 AM |
| Carbon fiber Kevlar hull? | Todd D | Fiberglass and Composite Boat Building | 3 | 11-27-2008 01:30 AM |
| Carbon/Kevlar Transom | Bullseye | Fiberglass and Composite Boat Building | 15 | 06-28-2007 08:16 PM |
| prepeg carbon/kevlar | the_sphincter | Materials | 1 | 11-22-2005 04:47 PM |
| e-glass vs. aramid/kevlar vs. carbon | JEM | Materials | 12 | 06-12-2005 03:19 PM |
