Old 11-25-2008, 11:37 PM
Todd D Todd D is offline
Rep: 10 Posts: 6
Carbon fiber Kevlar hull?
Hi, I am thinking of building an all carbon fiber or carbon and kevlar flats boat and was wondering what everyone would suggest as the best resin for the job? I was also wondering if I could build the hull without gel coat and not have to worry about water intrusion. The hull will never be left in the water for more than 8 hours at a time. What other problems might I come across over time like uv light affecting the layup? Trying to build a 22' hull that weighs under 1000 lbs.
Old 11-26-2008, 05:34 PM
Eric Sponberg's Avatar
Rep: 2447 Posts: 1,376
Practically all carbon fiber and Kevlar is sized (coated) with a binder that is compatible with epoxy resin, not polyester or vinylester. So, you are stuck with epoxy. I am a long time fan of Gougeon Brothers products, and you can't go wrong with their Pro-Set resins which are the best for laminating fabrics.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 11-26-2008, 05:56 PM
rasorinc rasorinc is offline
Rep: 678 Posts: 1,127
Here is some testing info on epoxies
http://www.oneoceankayaks.com/Epoxresl.htm
Old 11-27-2008, 02:30 AM
Rep: 2891 Posts: 8,792
Yep, epoxy is the ticket as it has the elongation necessary for these types of fabrics. Of course to insure the resin doesn't break down from UV, it will have to be over coated (painted), so the pretty look will get hidden. You do realize the cost of this type of laminate is going to be very high, right? An example would be a 2x2 plane weave 3K carbon fiber (6 ounce) is about $55 a yard, where as the same weight and weave conventional 'glass fabric is about $6 per yard, making the carbon nearly 10 times more expensive.
Carbon Fiber Hull over Shaped Urithane Foam Pablo4077 Materials 14 02-13-2009 01:01 AM
Performance mold wanted for carbon/kevlar hull tomuchstuff Boat Molds 0 09-29-2007 06:08 PM
Carbon/Kevlar Transom Bullseye Fiberglass and Composite Boat Building 15 06-28-2007 09:16 PM
prepeg carbon/kevlar the_sphincter Materials 1 11-22-2005 05:47 PM
e-glass vs. aramid/kevlar vs. carbon JEM Materials 12 06-12-2005 04:19 PM
