Old 12-22-2008, 05:09 PM
lausl lausl is offline
carpe diem yacht design
Rep: 10 Posts: 21
Canting keel bearings - Bulkhead attachm.
my first canting keel boat on the drawing board.
there are different ways to attach the bearings
of the canting axis to the load carrying bulkheads.
I am collecting different opinions, questions are:
Do we have to use sperical bearings
Should those be housed such that we can pull (uninstall)the
axis downwards
Are there bearings available of the shelf
Klaus
Klaus Roeder
Carpe Diem Yacht Design
www.yacht-design.de
Old 12-22-2008, 11:17 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
I would guess those bearings would be plain bronze with a stainless steel shaft or pin. The bronze might be wormed (a groove spiralling around the inner surface) so that grease can be pumped in (maybe powered by the swinging of the keel itself).
Neoprene O ring seals perhaps.
There are many ways to design an assembly that can be disconnected for repair or transport, and I imagine there are several different designs out there.
I'm just guessing. I have no idea how those mechanisms are actually built.
I'm just extrapolating from existing similar bearings used in boats in salt water.
Maybe someone can speak from experience.
Old 12-30-2008, 10:23 AM
Rep: 309 Posts: 589
Klaus
Since my disclosure of the most recent info I have on these systems would probably be frowned upon I will give some very general advice.
Hidden within the construction of the canting system (and this is somewhat dependent on size and how it is powered) there are many pitfalls. Precise alignment, adequate structure, and the use of the right materials, will only avoid most of the problems. If you haven't access to some well experienced coaching with this, I would proceed directly to Cariboni and have the owner pay them to design this thing. They are a notoriously difficult company to deal with but really the best choice. I can tell you that these things can be a nightmare, or they can be fairly straightforward. Having experienced help can make all the difference.
Canting Keel Design cmgreenwood Boat Design 3 11-08-2007 11:54 AM
Canting Keel Mechanisms SuperPiper Sailboats 88 01-05-2007 03:58 AM
Canting keel tamkvaitis Sailboats 3 01-08-2006 09:03 PM
why canting keel? freemanjunelee Sailboats 18 06-06-2005 05:37 PM
Canting Keel Design MrK Sailboats 28 03-19-2005 08:22 AM
