Old 09-04-2008, 04:53 PM
mongo75's Avatar
mongo75 mongo75 is offline
Rep: 95 Posts: 262
Can I make my own windows??
I'm not sure if I already asked this question anywheres, but I'm at the point in my resotration where I need to put some windows on the thing. I plan on having it about 6 feet ong, 18" high, 90* in the front and a nice sloping curve at the rear end (no jokes LOL) .
I've priced some marine window manufactures and they are pretty damned expensive for my budget. Can I just use some extrusions from Lowes and then have a glass company cut and temper some windows for me? And if so, can I get away with using 3/16th glass on a flybridge, or do I have to go with 1/4"? It's my impression that the glass doesn't, or rather shouldn't, support any of the weight of the cabin correct?
Please let me know if this is feasible!! Thanks !!
Danny
Old 09-04-2008, 08:59 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
it may not "support" anything,, but it does take alot of "pressure" against wind, waves, and flexing of the boat.i'd go with the 1/4. i know ya can get them made,,but i dont know bout them having it tempered after,,,,, never thought about it that deep,,hehe
hehe ,,,,,Jim------>
the1much's Avatar
huh? hehe ;)
Can I make my own windows??<< can ya blow glass? ,,hehe
Old 09-04-2008, 11:35 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
I'm planning to anyway..
Acrylic is the way if making curved windows in a carage.
Old 09-05-2008, 07:39 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Of course. Acrylic is lasercut very well. If you're a bit clever on the design they can even open and close.
Regards
Fanie
Water ! Just gimme water !
Old 09-05-2008, 05:09 PM
mongo75's Avatar
Rep: 95 Posts: 262
There's a glass shop not too far from where I live that can cut to shape and then temper the glass for me at a reasonable cost, vice the $2000 another company quoted me. If I was redoing a 50' yacht then $2000 would be a drop in the bucket, but to my military paycheck it's a different story. I was also thinking acrylic because I can do it myself, but am concerned with the eventual scratching of the plastic. The reason I wanted to use 3/16th is because I have 2 4x8 sheets of the stuff, and Lowes sells double channel 1/4" extruded aluminum I could use for a frame.
Danny
Old 09-05-2008, 06:16 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 563
Mongo,
I had to make mine to replace the ones that were blown out. You can get alum. extrusions and the Alum, male / female screw bolts that I forgot what they are called. I used dark bronze acrylic. Some advice - the plastic lays on the outer surface on a bed of mastic. Drill oversize holes for the thru bolts that Ican'trememberthemameof If you are using a 1/4" bolt make a 1/2" hole in the plastic. (keep the 1/4" for the alum. extrusion.) This will stop the crazing. Acrylic expands and contracts a lot.They will last about 2 years. Thats what I'm giving mine, but they are cheap and easy to replace.
Old 09-05-2008, 07:48 PM
mongo75's Avatar
Rep: 95 Posts: 262
The more I think about it, the better acrylic is looking. However 2 years is kinda short isn't it? But then again if it's even half as cheap as glass, then it'll be worth it. Just gotta be carefull cleaning them.
Danny
Old 09-05-2008, 08:21 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 563
It's a trade off. I needed to dry-in the deck and I didn't have lots of money. Of course glass is the best way to go, but we all have to compromise -- I learned---I'm married.
Old 09-07-2008, 10:16 PM
naturewaterboy naturewaterboy is offline
Steel Drum Tuner
Rep: 10 Posts: 210
There is some polycarbonate (tradename Lexan) that has a scratch resistant coating - kinda like a glass coating on the plastic - like expensive plastic lens sunglasses. It is available in different thicknesses. It is pricey compared to uncoated lexan if I remember right - but lexan holds up much better to UV than acrylic, and it is very, very difficult to crack. It's much easier to drill because of this. It also will stop bullets too.
Wherever you go, there you are...
Old 09-08-2008, 11:01 AM
mongo75's Avatar
Rep: 95 Posts: 262
Thanks waterboy!
And yes Jer, being married myself I feel your pain. I gotta sell stuff on ebay and recycle metal to pay for my boat, the wife gets pissed if I take too much outta the budget for the boat. Women just don't understand!!
Danny
Old 09-08-2008, 07:15 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 563
Yep, I should have said I only compromise my materials. There is no compromising with the wife.
Old 09-09-2008, 01:58 PM
TeddyDiver's Avatar
Gollywobbler
There's some differences btw female's of the western and the third world. No explanations needed anymore
Old 09-26-2008, 04:36 PM
Arildo Arildo is offline
Rep: 10 Posts: 16
Hi there (kinda late?)
You should be very careful about using plexiglass (/lexan?) because they tend to crack over time! Acry is a much better choise - as they dont crack so easily. Plexiglass has a better protection against scratches, but you have to be extremely careful of the installation methode - using rubber all the way around, also in the screw holes. And never put any force to it, as it will for sure crack over short time...
Old 09-26-2008, 05:51 PM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 679
Can you apply window tinting film over the acrylic to slow down the " crazing " that always seems to happen ?
Where can I get windows from? mongo75 Fiberglass and Composite Boat Building 2 08-25-2008 10:43 AM
Streamlining Windows XP (?) LP General Computing 6 01-18-2007 01:45 AM
Flush mounted windows fhrussell Boatbuilding 1 03-21-2005 12:51 AM
Bonding windows in trawler Scratchy Dan Boat Design 9 11-14-2004 10:19 AM
Reasonably priced windows goBoating Materials 1 03-18-2004 09:32 PM
