Old 06-10-2011, 02:11 AM
Tallulah Tallulah is offline
Tallulah
Rep: 10 Posts: 2
Can a fibreglass boat skin be too thick so affecting buoyancy?
Hi, My dad had been building a 22ft cabin cruiser. The hull is complete as far as fibreglassing and one side is sanded. The other side isn't sanded due to inaccessibility (he built it in a garage) My dad has now passed away and it is my job to find a new home for the boat. If my dad had added too many layers of fibreglass and resin, could this affect how low the boat will sit once she's fitted out etc. He once mentioned (to my brother) that this is what he had done apparently to make the hull stronger)
Old 06-10-2011, 02:40 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
More weight = deeper in water. That is simple.
How much weight and how deep in the water, and if that can be called "wrong" is totally upon the user.
Old 06-10-2011, 05:50 AM
Rep: 3125 Posts: 9,399
The thickness of the hull shell will effect the displacement of the boat, but not my much. If you have a hull that's suppose to be a 1/4" thick and you made it twice as thick, the extra 1/4" of laminate will make the boat sink down a little, but we're talking fractions of an inch here.
Old 06-10-2011, 02:10 PM
Tallulah
Rep: 10 Posts: 2
Thanks very much for the info. I feel happier about rehoming the boat now. I didn't want to pass on a pig in a poke and thought I may have it cut up.
Skin on frame pontoon boat? Artifex75 Boat Design 10 03-19-2011 12:09 PM
fibreglass boat tahtoh25 Fiberglass and Composite Boat Building 2 10-07-2010 09:18 AM
How to determine stability (and buoyancy) of a very slender boat? JotM Stability 13 05-07-2009 08:11 AM
Fibreglass Boat Graveyard ?? RHP Open Discussion: All Things Boats & Boating 3 09-21-2008 03:24 PM
skin thickness for small boat stephen smalzel Boat Design 6 06-28-2004 08:43 AM
