Old 02-13-2012, 06:13 PM
therigwelder therigwelder is offline
Rep: 10 Posts: 30
Can blue board be glassed with polyester resin?
Can blue board be glassed with poly?
Old 02-13-2012, 09:17 PM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
I am assuming you are talking about extruded poly styrene from Home Dumpo or Lowe-st...no. Polyester will melt the styrene into goo. You would have to use epoxy for that.
Steve Lewis
Lewisboatworks
http://angelfire.com/ego/lewisboatworks
Old 02-13-2012, 09:41 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
There are some polyesters that will work, but you need to special order it.
Old 02-14-2012, 09:56 AM
lewisboats's Avatar
Obsessed Member
I would expect that they would cost close to the same as epoxy so I don't see the benefit.
Steve Lewis
Lewisboatworks
Old 02-15-2012, 06:16 PM
tropicalbuilder tropicalbuilder is offline
Rep: 38 Posts: 32
i've been able to use poly over styrofoam priming the styrofoam with white glue.
The vinil based white glue used by carpenters for wood.
As my foam was white i put some black pigment in the glue so to be able to see any void while painting.
I also found that it is better to prime with one coat of resin, let it set and then go on with the laminations.
Old 02-20-2012, 02:10 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
You can apply a layer of the special polyester, and after cure laminate further with normal polyester. That is the benefit.
Old 02-20-2012, 02:47 PM
Rep: 288 Posts: 662
Correct, and the cost is less than epoxy.
Using polyester resin as a varnish. Frosty Open Discussion: All Things Boats & Boating 12 04-09-2011 09:16 PM
But first, a word about polyester resin gaffer Fiberglass and Composite Boat Building 7 12-01-2008 10:30 PM
trouble with polyester resin restornator Fiberglass and Composite Boat Building 2 07-30-2008 03:50 PM
Polyester resin as a primer? crosscut Wooden Boat Building and Restoration 5 03-24-2008 05:36 PM
Polyester resin roko Fiberglass and Composite Boat Building 10 11-28-2005 07:39 AM
