Old 04-06-2005, 06:05 PM
Bill Kaputnik Bill Kaputnik is offline
Buyer trends for cored hulls?
Lot of you guys building should know answers to what sells, seems like. I wonder if buyers tend to shy away from boats built with cored hulls? My perception is that a large number of people shy away from cored hulls.. Any feedback?
Old 04-06-2005, 07:51 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
No my personal experience is they prefer a cored hull in my end of the business..
Slippery when wet.
www.cheetahcat.com
Old 04-07-2005, 01:23 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Unfortunately, you're quite correct, a common perception is that cored hulls will flood with water at the drop of a dime, and yes, a lot of cored boats have been built very poorly. In the case of hulls built with slit coring, as long as the slits are filled with core-bond putty, all the individual squares will be segregated, and consequently flooding will stop at the next undamaged bondline. When it comes to unslit foam-coring, the closed cells will slow the water migration quite considerably, but proper installation of thru-hull fittings and all other penetrations is always imperative.
It's all a matter of understanding the degree of workmanship required.
Yokebutt.
Old 04-07-2005, 01:52 AM
Rep: 84 Posts: 661
The only way to build a large composite yacht is thru sandwich construction Period the days of some heavy solid glass monstrosity are over and have been for 25 years , In the Ultra high performance arena the only way to achieve the stiffness required for a boat to run around 200 mph is thru the same. The simple vacuum bagging/clamping and wet/bagging techniques in use for a couple decades guarantee integrity along with the modern “Approved” core selections and resins...
Beware of hand contact pressure anything in a hull!
Slippery when wet.
www.cheetahcat.com
Old 04-07-2005, 02:18 AM
Boatbuilder
Rep: 15 Posts: 545
I'll second War Whoops sentiment!
Yokebutt.
The Ideal Cruiser - a long range passagemaker D'ARTOIS Projects & Proposals 306 07-15-2011 07:54 AM
Radius Chine Hulls Inerested Boat Design 7 02-12-2008 08:04 AM
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
A Tale of Two Hulls.... BCBoater Boat Design 6 09-05-2003 02:48 AM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-26-2002 12:26 AM
