Old 08-11-2005, 10:34 AM
dman dman is offline
Rep: 10 Posts: 12
bulkhead tabbing
I have a late 60`s 36c Seafarer ketch/tank,the hull is glass.There are areas where the bulkhead tabbing has seperated from the hull.The issue that I have is that the tabbing runs continuous and there are no breaks.Wouldn`t this cause hard spots on the hull?Since this appears to be factory should I repair it the same way?Thanks
Old 08-12-2005, 06:28 PM
jimslade jimslade is offline
Rep: 14 Posts: 304
as long as there is a space between the tabs it should be fine.
Carbon tapes for tabbing? henrikb Fiberglass and Composite Boat Building 7 04-20-2005 01:29 AM
Bulkhead materials and chainplates zaney Sailboats 3 11-11-2004 03:42 PM
bulkhead question 8knots Boat Design 3 05-11-2004 11:15 AM
Water tight bulkhead door kudu Boat Design 12 06-27-2003 09:46 PM
