Old 11-26-2005, 09:13 AM
signum signum is offline
Rep: 10 Posts: 20
building with PVC core foam
I wish to know if is it possible to work with PVC core foam as plank on frames method similar with marine plywood plank on frames ?
I was thinking just to laminate with epoxy fiberglass a face, let it cures and than to try planking the laminated sheet on frames with fiberglass face up, I mean to be the exterior of hull. Will it have enough flexural strength don't break the PVC foam? I think to Herex C70.90 from Alcan airex which is a good core for small hull projects. I wonder just if the exterior of hull will be enough smooth after the first lamination with fiberglass on the exterior face. I think should be. I know that lamination must be a first layer of resin on PVC , next a layer of chopped mat , resin again, roving fiberglass bi axial, and again resin.
Has anybody other opinion?
Thanks
Signum
Old 11-26-2005, 10:26 AM
D'ARTOIS D'ARTOIS is offline
Rep: 83 Posts: 1,068
I don't believe it's a very good idea for a variety of reasons.
If I understand you well, you will use long strips of core (Airex) fasten that to the frames and than laminating the exterior face.
First of all, I do not believe hat you will be able to get a fair hull i.e. that the so called "core planks" will remain straight and will not lex whilst hardening out if laminated.
I don't think you won't get a smooth hull either bu that depends also a bit how you build up the layers whilst laminating.
A 3rd reason not to do it you will not get continuous strength in your laminate because each frame interrupts the continuity of the laminate.
This is how I see it.
Old 11-26-2005, 11:06 AM
Rep: 299 Posts: 2,409
However for a repair of a really fine classic ,
with unobtainable woods & workmanship a case for foam planking can be made.
Invert the hull, and with a heavy grinder get the fastenings visable and cut around them.
Number each plank .
Trace the plank shape in Airex , wrap the plank with matt and use a SS meat skewer to hold the plank against --- into the rib where it came from.
When all planking is replaced glass the outside with single skin scantlings.
Fair as you go , and the result will be fast light ,quiet, insulated , and as maint free as any plastic boat.
Downside , Airex is hardly cheaper than Gold!
Got a nice 75 ft'er to do?
FAST FRED
Old 11-26-2005, 07:02 PM
Ssor Ssor is offline
Rep: 10 Posts: 174
Check out coreplank it is made by CoreCell, It is two inch wide cove and bead strips made for building boats from moulds just as you would build a wooden boat that was to be covered with fiberglass. It can be obtained in lenths of sixteen feet, about five meters, and in a variety of thicknesses.
Airex PVC core foam using ? signum Fiberglass and Composite Boat Building 10 02-01-2009 03:26 PM
Selecting foam core TomE Materials 14 01-07-2006 04:18 AM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 06:00 PM
PVC foam core thickness? Danielsan Fiberglass and Composite Boat Building 37 02-10-2005 12:45 PM
Gluing pvc foam core Boatbuilding 4 02-12-2003 02:25 PM
