Old 01-09-2005, 09:50 AM
gesdim gesdim is offline
Rep: 10 Posts: 3
polyethylene small boat building
Hi all,
I call about dilemma between steel or polyethylene boat building; I want to build about 8' long dinghies, and about 60 lb(P.E.) or 80lb (steel) weight;
boat usage will be in summer time (about 3 months), on big mountain lake, there are mostly gravel and stone beach, with possible sudden weave; most usually local boat are rivet steel boat, smaller from 8' to 10', bigger to 21', manufactured in local tinman workshops ; local polyester boat factory produce only expensive 13' open boat and bigger. I plane to build polyethylene boat similar as rigid inflatable boat, (welding method with special electric dryer and electrode), from polyethylene tube (diameter 10")(chambers), polyethylene plate 1/4"(hull) and p.e. plate ~1/2" (stern), of course with necessary ribs . Polyethylene boat is safe, without needful maintenance, maybe only keeping can be problematic ( resistance from low temperature (surface freezing), or from high temperature in summer (locally softened); same, polyethylene boat can't be sink in the water (because winter keeping ).
regards from lake Ohrid, Macedonia, Europe
Boat building project in Sri Lanka gamage Post-Tsunami 82 11-20-2008 02:58 AM
TP52s mighetto Sailboats 2052 09-06-2007 11:46 AM
Building small pontoon boat. Ideas? drose Boat Design 1 07-21-2005 07:02 PM
New to Boat Building. I need guidance. mackenzie447 Wooden Boat Building and Restoration 2 06-29-2005 11:51 AM
new boat building method Guest Boatbuilding 2 09-24-2003 03:55 PM
