Old 02-26-2007, 02:32 PM
custom30 custom30 is offline
Rep: 10 Posts: 24
Building a new sailboat
I have the moulds and tooling for a popular very well designed 30 footer..I am going to start construction..I want to build it light and strong..I don't want to follow the original layup as it was designed for the MORC rule...any suggestions..?
Old 02-26-2007, 02:54 PM
Eagle Boats Eagle Boats is offline
Rep: 16 Posts: 169
I don't think anyone in this forum can, will or should offer any suggestions regarding a layup schedule. You should speak with a naval architect. There are many variables involved here.
I do not mean to come off harsh. Can you imagine what would happen if you built a boat based on a recommendation received here, the boat sank and there was a loss of life? Do yourself a favor, spend a few bucks and do it correctly right from the start.
Old 02-26-2007, 02:58 PM
Rep: 10 Posts: 24
well you are entitled to your opinion..thanks..but what is the point of having a forum called FIBREGLASS AND COMPOSITE BOAT BUILDING if know one wants to offer suggestions...
Old 02-26-2007, 03:54 PM
Rep: 16 Posts: 169
I don't want to get into a pissing match with you. I am just trying to offer sound advice. You asked for a suggestion, and I gave you one.
As I had stated previously, there are many variables involved before anyone could give you the slightest advice as to what the layup schedule should be. For example, the shape of the hull, the target weight of the boat, the sail area of the boat, the shape and weight of the keel, type of rudder. These are just the beginning. What type of resin are you plan on using, are you going to core the hull, and if so, what core.
I am not trying to discourage you. Again, just do it right. Speak with a marine architect. Give Dave Gerr a call. He is located in Manhattan, NY. He is very approachable.
Old 02-26-2007, 03:59 PM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
Fantastic suggestion
Custom 30, getting an NA is a fantastic suggestion- they save you time & $ in setting out a build & layup sced that is engineered to cope with the loads of keels, shrouds etc, that means you build faster, lighter etc & don't have to make any guesses on layup. Responses on this section of forum are often by tradies, techs, slushies experinced in the application & use of composites, whilst that may make them excellent practical engineers it don't make em professeional engineers like a qualified NA.You gotta start right to finish right & that means getting good design information.Regards from Jeff
Old 02-26-2007, 06:14 PM
Rep: 505 Posts: 1,637
eagle is right ,,,,,what if I tell you Im a na,,or designer,,,im not ,im just a old fisherman taking forever to build my boat,,,,longliner
Old 02-27-2007, 03:55 AM
Rep: 3125 Posts: 9,399
I'd be more then happy to offer a laminate schedule, but have no idea what you have or want, which tends to make things imposable. A laminate is an engineered structure, requiring a reasonable understanding of the properties and stresses involved in the materials and vessel.
Contact me through email and we can iron out your concerns.
Old 02-27-2007, 08:07 AM
Rep: 10 Posts: 24
I will post the layup schedule I have at the moment its rougly 8-10 yrs old...i want to up date it . As i have said the boat was built to the MORC rule originally which means it is heavier than needed..I want it just as well built just lighter.
thanks
Old 02-27-2007, 08:10 AM
Rep: 10 Posts: 24
this is the boat
Building a new sailboat-andrews30a.jpg  Building a new sailboat-andrews30b.jpg
Old 02-27-2007, 05:29 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
It doesn't look to heavy :-)
Why do you want to build this boat?
Is it for racing? Under what rules?
What's wrong with MORC? I searched about it and it's still active(?)
Why does MORC mean heavy?
The Olson 30 sailed under MORC and is quite light,
http://en.wikipedia.org/wiki/Olson_30
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 02-27-2007, 05:33 PM
Raggi_Thor's Avatar
Just as strong but lighter?
If you don't mean sandwich, use a stronger laminate (resin and fibres).
DNVs rules for grp use a formula like
New thickness = Old thickness x (Old tensile strength / New tensile strength) ^0.5
So, if you test your new laminate and find it's twice as strong, you can reduce thickness by 30%.
www.MBOATS.no
Old 02-28-2007, 05:58 AM
Raggi_Thor's Avatar
Maybe an interesting article for you in the last Professional Boatbuilder, February/March 2007, page 32 "By the book",
http://www.proboat-digital.com/proboat/20070203/
www.MBOATS.no
Old 02-28-2007, 07:59 AM
Rep: 10 Posts: 24
all of these boats are being currently updated..keels and rudders. the boats originally weighed in at close to 8000 pounds..they were designed around MORC and pushed the envelope for taking advantage of the rule itself. MORC is pretty much dead on the great lakes and I/We will be sailing the PHRF rule.
Old 02-28-2007, 08:04 AM
Rep: 10 Posts: 24
I will also try to have the laminate schedule that is currently used..once that is shown is it possibel to perhaps have it tweaked. I guess what i am asking is there somthing better out there to come up with the same toughness but only lighter ?
Old 02-28-2007, 08:13 AM
Raggi_Thor's Avatar
You should discuss this with a designer in your area,
but,
with single skin you can go lighter with better (more expensive) resin and fibre, you need to test the resulting strength and stiffness with the old and new layup,
with sandwich you can probably save more weight, at a cost,
with more frames and stringers or other stiffeners you can use a thinner skin.
www.MBOATS.no
how to's "building a wooden sailboat mast" fishweed Wooden Boat Building and Restoration 8 12-23-2006 07:32 AM
I want to start building my own sailboat... madalin Sailboats 17 07-04-2006 11:46 PM
Which sailboat? bettyswallocks Sailboats 4 09-22-2004 09:59 PM
Sailboat Plans rgranger Sailboats 1 02-05-2004 09:16 AM
New sailboat design rjm Sailboats 3 10-10-2003 10:39 PM
