| building a corecell deck I am building a 32' sailboat and would like to use 1/2 core cell instead of 1/2 plywood for the core. The design calls for 24 oz woven roving on both sides of the core. I wonder how to lay the deck using corecell? Should I use plain corecell and force it into a 1/24 camber? If so, how would I get the inside layer of 24 oz roving between the deck beams? If I put the inside roving on first, the core cell might be to stiff to make the camber. Alternatively, if I thermoform the corecell to the deck camber, then remove it from the deck and lay the roving in, would the piece fit back onto the deck? Any help would be appreciated. |
| I'm not sure how well you'll like this idea but... ...you could make a mold of the underside of the deck. Use two long solid boards as "stringers", then cut some plywood frames with the 1/24 camber, attach them to the stringers and bend a sheet of plywood over them. Now lay some plastic over this plywood (or formica), spray down mold release, and lay up your fiberglass, foam, and fiberglass sandwhich. Vacuum bag the deck sandwhich to the mold. After it has cured, pull the deck out and cut it into shape (if you didn't do that first). |
| Building a center cockpit deck. Advice needed Please. | Jabula | Fiberglass and Composite Boat Building | 6 | 02-15-2006 08:41 AM |
| help on divinicell or corecell kiteboard core | surferazul | Fiberglass and Composite Boat Building | 1 | 02-03-2006 06:35 PM |
| Building a pitching deck on a 16 ft. V-hull Questions? | cwen | Boat Design | 1 | 12-20-2005 06:52 PM |
| Corecell 3 mm and 6 mm - Ontario Canada | Rogue Wave | Marketplace | 6 | 07-15-2004 03:19 PM |
| Want to replace old Mako 19 deck with a "Flats boat deck" - am I crazy or what ! | dan | Boatbuilding | 4 | 09-24-2002 04:48 PM |
