Old 12-29-2006, 09:44 PM
COLD-EH''s Avatar
COLD-EH' COLD-EH' is offline
Rep: 10 Posts: 62
Build and Run Plug
Happy holidays! I am building a hull and I have an old 16 1/4' deep v hull with about 23' sides at the transom and I just read a reply by samsam that build and run plug then mould it. I was going to cut this hull apart at the first lift strake and add a flat section to accheive total 8' width. 2' wide flat where the point used to be and probably 58" wide flat or similarity of that. So I am wondering if I should cut and paste ( I know it will be a little heavier) and try it first?. It's actually going to be a hard chine "river and ground" AIR boat with a 489 BBC with 2.68 reduction and 3 blade superwide. I like the idea!
If your cad software were ported to run native on any OS, would you: Jeff General Computing 16 02-29-2008 09:15 AM
Raft for Poker River Run maryann Boatbuilding 1 08-04-2005 05:48 PM
Whats the best way to run my light? Lil John16 Electrical Systems 2 06-06-2005 04:21 PM
New Zealand: Investors Sought, Production Run, Cats eastcape Services & Employment 0 03-08-2005 05:10 AM
Buying a boat for ICW and Bahamas run; advise on quality/min spec please kattz Powerboats 2 08-01-2004 11:54 AM
