Old 08-31-2006, 10:01 PM
JC47 JC47 is offline
Rep: 10 Posts: 17
Bronze Skeg
I am rebuilding a Stevens 47 sailboat. I had to remove the bronze skeg cap which is about 2 1/2 feet long. It is of course hollow and bolts onto the skeg stump made of FRP. My question is before I re-attach it what can I do to prevent any corrosion may occur. A boat building buddy recommend filling it with epoxy, the extra weight would not be an issue. My initial thought the if any moisture was able to get between epoxy and the bronze that would be worse than a open space. What are your thoughts or would what material would be a good to prohibit corrosion. When I bolt the skeg back on I will force 5200 around it prior to bolting. JC47
Bronze/ Stainless screws Bremner Wooden Boat Building and Restoration 7 04-29-2006 08:30 AM
silicon bronze vs stainless steel Ralphw Wooden Boat Building and Restoration 21 02-03-2006 08:29 PM
removing skeg tom4660 Boat Design 4 01-21-2006 12:28 AM
Bronze/aluminium freeze-up Bergalia Boatbuilding 10 10-17-2005 06:53 PM
Restoring Bronze winches fhrussell Wooden Boat Building and Restoration 10 06-17-2005 08:09 PM
