| Bronze scupper/drain/bailer I am trying to find a bronze thru hull that allows water to pass thru when a boat is out of the water, but plugs up when the boat is in the water. The thru hull has a rubber ball, the size of a tennis ball, contained inside it. When the boat is in the water, the ball floats up against the thru hull and prevents water from going up. Any help in where I can locate this will be greatly appreciated. Worse comes to worse, I will be busy on the lathe! |
| Scupper Size | RDB | Boat Design | 3 | 08-08-2005 12:42 PM |
| Proper drain hardware? | Mark V | Boatbuilding | 3 | 01-09-2005 04:46 AM |
| scupper designs | RGG | Fiberglass and Composite Boat Building | 7 | 05-17-2004 08:07 PM |
| Bollard/scupper design | BrettM | Boat Design | 17 | 01-21-2004 08:35 AM |
| scupper placement | Armand Salese | Powerboats | 3 | 09-22-2001 02:33 PM |
