Old 01-06-2011, 12:26 PM
grpqueen grpqueen is offline
Rep: 10 Posts: 14
bowsprit design 47ft motor boat
I am building a motorboat out of an old mould I was given, but it needed tweeking.
I have stretched it 4ft longer and 2ft wider. The bow was a temp stitch together, I have started to peeled back the mould at the bow, the stem has turner out great, but she seems a bit bull nosed at the top, I was considering adding a bowsprit to improve the shape,
I am a laminator not a boat designer and wondered if any of you clever chaps might have some good pics or drawing you might like to share?
many thanks grp
Old 01-06-2011, 01:27 PM
Rep: 1493 Posts: 7,447
Can you post the lines or photos?
Old 01-06-2011, 08:36 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
grpqueen, so how did you increase the beam, just separated the moulds two feet...that would give you a very rounded bow.....we need more details to be able to give helpful advice instead of simple comments.
Old 01-30-2011, 06:29 PM
Rep: 10 Posts: 14
photos
She has a flared bow and very round nose at deck level , i can post a couple of the mould and a some of the inside of the boat and a couple of the bow out of the mould as the boat takes up all of the shelter cant get a clear view, hope this helps, grp
bowsprit design 47ft motor boat-236.jpg  bowsprit design 47ft motor boat-238.jpg  bowsprit design 47ft motor boat-150.jpg
bowsprit design 47ft motor boat-mould.jpg  bowsprit design 47ft motor boat-246.jpg  bowsprit design 47ft motor boat-201.jpg
Old 01-30-2011, 07:03 PM
Rep: 10 Posts: 14
landlubber, i hope pics give some info.
yes i did just jack her apart 2ft,
it took a bit of work to repare the mould and fake it back together well, but as i intend to dispose of the mould when im done, the stitch together was temp , to be used once.
Old 01-30-2011, 09:41 PM
Landlubber's Avatar
OK, so with the moulds two feet apart, refabricate a temp mould to follow the same bow lines, they will meet about 6 to 8 feet ( I guess) in front of the current loa.
Do it with lamipanel, screwed onto the moulds, the inner surface will need very little tidying up when demoulded.....use plasticene at the joints to do a temp fill, but remember the boat is easier to sand back than the mould is to sand down....and yes the boat will increase in length, but at least it will have a pointed bow, and the lines will flow naturally from the original.
Old 01-31-2011, 10:46 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Ah a glass person after my own heart !!
Make a recess in the deck and make a seperate moulding of you bow sprit that can be bolted into the recess you manufacture into the deck . Use mainly unidirectional glass and double bias to hold all together and it will be like a greek war ship . Can mount your capstan and bollard etc etc all on the one moulding Just make sure you do your home work on the manufacture of your recess . If you have a deck mould just incert a packer in the from to take the new bow sprit shape .
Making beautiful boats is a passion never a chore !
Old 01-31-2011, 02:26 PM
Rep: 10 Posts: 14
hi land lubber , I have all ready built the hull with a gellcoat finish, no need for major sanding. no i did not follow the orignal lines, just wanted some neat ideas for a bow sprits, lol
Old 01-31-2011, 03:42 PM
Landlubber's Avatar
...yeah, of course, sorry, just thinking out loud....anyhow, one very strong way to make a bow sprit is with well seasoned hardwood, get some old demolition wood, shape it up and glass it all in, it is surprisingly strong and stable. You will need a bow sprit cos the anchor will bash the short flat nose to death.
Bowsprit design - Resolving forces ODL Sailboats 11 08-19-2010 09:41 PM
Design of Netherlands (traditional ?) open motor boat watchkeeper Boat Design 2 07-28-2010 06:12 PM
kite propelled motor boat design gabdab Boat Design 5 06-17-2009 08:17 AM
Retractable Bowsprit 35 foot sports boat robbo007 Sailboats 10 11-04-2007 04:51 PM
Bowsprit design LP Boat Design 2 04-04-2007 09:25 AM
