Old 09-09-2011, 03:10 AM
seymourperry seymourperry is offline
Rep: 10 Posts: 3
Boat hull restoration advise needed
I’m currently in the process of restoring a Tremlett 19. Having stripped the old deck and deck beams out I noticed the bow tank (now removed) must of sprung a leak at some stage and the plywood inner core in the bow was rotten as hell.
As you’ll see from the pictures I’ve started to strip back the rotten wood leaving most of the bow now right down to the fiberglass hull and there is about 10cm at the top of the hull which is also rotten through water ingress probably due to not being properly covered up by previous owners.
In addition the stem from the keel line to the front of the bow is rotten and needs to be replaced.
My question is, in order to get back some of the rigidity of the original plywood inner core and tops of the hull what is the best way to re-line it, is it as simple as cutting some replacement marine ply sections and then fix them on to sound boards and the exposed fiberglass hull or is there a stronger method I should use to integrate the new inner to the existing and dry ply?
Thanks for all your help in advance.
Old 09-10-2011, 12:20 AM
Rep: 1493 Posts: 7,447
From the photo it looks like a cold molded hull with fiberglass sheathing. If you want to keep the original shape and have a fair hull, you will have to build molds to support the skin so you can lay the wood veneers inside.
Old 09-10-2011, 01:44 AM
m3mm0s rib's Avatar
m3mm0s rib m3mm0s rib is offline
Rep: 31 Posts: 111
Thoroughly clean and plywood and put back the missing pieces. The association of a spar with the other should be 45 degrees and glued together with epoxy. Make some scratches on the plywood and put your hands mat needed to have the same thickness as the original. If you do not have space problem, you can put a picket fence.
m3mm0 SR ib http://www.youtube.com/watch?v=5kwlNk7-iSg
Old 09-10-2011, 09:11 AM
This link will give you some information on the construction of those boats. It is not plywood you are taking out but cold molded veneers.
http://www.timesonline.co.uk/tol/com...cle3252758.ece
Old 09-10-2011, 11:05 AM
m3mm0s rib's Avatar
Rep: 31 Posts: 111
okey my friend
Fiberglass boat restoration help needed bear23 Fiberglass and Composite Boat Building 5 05-09-2011 06:35 PM
hull design/advise needed flyinwall Boat Design 0 03-09-2008 05:52 AM
1980's Power Boat advise needed CARIB Open Discussion: All Things Boats & Boating 2 01-19-2008 11:20 AM
Tri Hull Advise needed finnyct90 Open Discussion: All Things Boats & Boating 2 04-17-2007 12:57 AM
Structural advise needed to correct poor boat construction sbklf Fiberglass and Composite Boat Building 9 09-27-2006 07:36 AM
