Old 10-28-2010, 05:11 AM
Littleship Littleship is offline
Rep: 17 Posts: 5
Boat cradle design
Probably a simple matter but one I just cant grasp on how to safely support the boat while its worked on. The boat in question is a coronet seafarer 27, 8.22m length, 3.16m beam with a .91m draft with a 4000kg displacement. I would like to build a cradle for the boat to sit in while it has work done which will safely support it while allowing people in and on it. Something similar to this http://www.boatshop24.com/web/en/wer...=1&lastshow=75 I'm unsure what points of the hull are best to run supports onto and over what length the stand should run. Any thoughts or other idea's would be helpful.
Old 10-28-2010, 09:04 AM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
You Can not just support the keel and use yard jacks/jack stands to stabilize it?
Slippery when wet.
www.cheetahcat.com
GRP impact from storage cradle delboy Sailboats 2 01-27-2009 06:25 AM
Meridian 381 Sedan - Please help to build a cradle Aurochs Fiberglass and Composite Boat Building 0 06-13-2007 03:42 AM
off trailer & on to cradle ?? pescaloco Fiberglass and Composite Boat Building 7 02-22-2007 07:44 AM
Cradle to support the mold? tiger1047 Open Discussion: All Things Boats & Boating 0 01-25-2007 09:00 AM
how to build a cradle for a tri hull boat bigbearfireman Fiberglass and Composite Boat Building 1 03-20-2006 08:22 PM
