| boat bottom help. i have a 2005 16dlx carolina skiff that was used as a part time landing craft on rocky shoreline, a barge, and party craft. sat in salt water for 4 straight months. then given to me as a dept settlement. After removing the barnacles its left me with a very beat, chipped, and gouged gel coat under the water line. Now i want to get the hull looking good again but am unsure if its worth spraying the outer hull with gel coat. I am also considering filling the voids then painting with imron or something else good. if anyone could give me some pros and cons of these ideas or hopefully even betters ideas i would appreciate it. -cody |
| Give it a good sanding with 40 grit, fill the voids with a mix of gelcoat and cabosil, sand with 80, 150, 320 grits and spray gelcoat with Duratec clear additive.
__________________ Gonzo |
| thanks for the help |
| Help building a 17' long x 50" bottom flat bottom aluminum boat | Loewman | Boat Design | 22 | 11-21-2011 12:31 PM |
| 26' Pad bottom with 2 step bottom hull mold only | johnboat75 | Marketplace | 1 | 03-07-2009 07:00 AM |
| Redoing the bottom of a boat help | simba71 | Boatbuilding | 5 | 04-29-2006 10:32 AM |
| boat bottom | splitshot | Wooden Boat Building and Restoration | 27 | 11-17-2005 01:37 AM |
| Flat Bottom Boat | Marsh Man | Open Discussion: All Things Boats & Boating | 9 | 05-18-2004 03:01 PM |
