Old 06-07-2010, 02:05 AM
bmwtechie bmwtechie is offline
Black area in fibreglass
I am currently stripping my fibreglass Hull for repair, the floor had rotted away, so decided to strip it right down to the bare hull, every hollow area of the Hull is filled with Foam, which holds alot of water, I have had the boat under cover for 1 year, and the foam is still full of water, there is one corner near the transom where the fibreglass is Black and seems soft?
Firstly what is this that i am seeing? is it the wood of the transom rotting through the fibreglass?
I am planning to strengthen the transom with 18mm more thickness by glassing in another layer of Ply, is this a good idea?
Any help on this black area would be appreciated
Thanks
Old 06-07-2010, 05:08 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
It sounds like black mold and rotting wood to me. That will have to be cut out and replaced/reglassed. I don't envy you. There are threads addressing those methods here. Do a search under "mold" or "rot".
Hoyt
Old 06-07-2010, 05:12 PM
hoytedow's Avatar
Resistor
http://www.boatdesign.net/forums/sea...om%20stringers
Hoyt
Old 06-10-2010, 03:13 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Are you going to cover the old with yet more wood and glass ??
When you say another layer of ply wood do you mean over whats there ?
If you are intending to cover the old you are a nut case . what do you think will happen , the rot wont stop it could even get worse and rot quicker . it feeds its self and sealed it has its own coccoon for the spoors to breed in .
Plus the weight of the wet plywood and then another layer and yet more wet plywood
Old 06-10-2010, 03:15 AM
old one !
The black area you need to dig into it and find what it is !! dont be afraid just do it !!!
Old 06-12-2010, 07:54 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
In the Netherlands we have a saying: gentle doctors make smelly wounds.
You get the picture: Out comes the angle grinder! Grind away whatever you do not like, and rebuild to your (or our) standards.
Old 06-12-2010, 08:28 PM
old one !
theres possibly damp under the glass and coming up through the glass where there are tiny hold through to the core under the glass layer . it'll be wet for sure so use a good course disc on the grinder and have fun !!
Old 06-12-2010, 11:57 PM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1348 Posts: 2,055
Originally Posted by bmwtechie View Post
there is one corner near the transom where the fibreglass is Black and seems soft? Firstly what is this that i am seeing?
Might also be a "burn" in the lamination process- too much hardener, too thick layer.. What ever, grind it away..
Old 06-17-2010, 06:41 AM
Typhoon Typhoon is offline
Rep: 150 Posts: 125
I like that saying, I might start using it!
As for bmwtechie's boat, I've seen production boats laid up with a dry laminate and mould gets in and grows in the fibres on the surface. If you are lucky, that's what it is.
Regards, Andrew.
Old 06-17-2010, 06:44 AM
Herman's Avatar
Resininfusion.info
Yep, the Dutch are not so bad... (well except for Joran van der Sloot, I guess)
So as for a quick repair: get the grinder running!
Old 06-17-2010, 07:29 AM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 272 Posts: 553
...and rebuild to your (or our) standards.
Hahahahahahaha! Indeed.
black smoke bogs down mark_fitzy Gas Engines 9 08-04-2009 10:42 AM
Matte Black Boat mhooker Boat Design 14 01-17-2008 08:39 AM
Mercury Black Scorpion dick stave Inboards 2 12-03-2007 11:30 AM
sail area to lateral area ratios Ian Boat Design 5 04-07-2004 05:39 PM
mercury black max erik80 Powerboats 3 09-29-2003 10:29 AM
