Old 07-25-2007, 08:27 AM
sbklf sbklf is offline
Rep: 10 Posts: 43
Is it better to sand a resin rich repair or leave it alone
I am working with epoxy and have been sanding excess resin puddled at the bottom of 90 degree corners. I thicken resin applied to vertical surfaces but dont have mix ratios down yet. When sanding I am careful to stop when I hit glass and add a layer if I cut into it too deep. I know resin rich repairs are weak but is it better to leave it alone?
Old 07-25-2007, 09:46 AM
jimslade jimslade is offline
Rep: 14 Posts: 304
Resin rich repairs are only weak with polyester resin. Epoxies are usually flexible enough to discount this probability.
Old 07-25-2007, 10:09 AM
Rep: 10 Posts: 43
Thats good to hear, Thanks
Old 07-26-2007, 06:12 PM
johnnyv johnnyv is offline
Rep: 12 Posts: 17
Not true, improper mix ratios with epoxy give a weaker product. 5% by weight off on one of the components is usually fine, with greater variations tensile strength degrades significantly.
Old 07-26-2007, 06:40 PM
alan white's Avatar
Rep: 1168 Posts: 3,270
I believe the reference was to cured resin to glass ratio. Polyester has little strength on its own. More resin than is needed to saturate the cloth simply adds weight and a tendancy to crack under stress or hot/cold cycles. Epoxy has some elasticity and performs a structural role without cloth.
Alan
Old 07-26-2007, 06:54 PM
Rep: 12 Posts: 17
Alan
Ah i was seeing that as resin as in the resin component also mix ratios was related to filler.
I shouldn't skim in the morning
Old 07-30-2007, 08:20 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
how thick is the puddle?, and where is it?,inside hull, outside on deck?, . if its noplace of any concern and not thick,,leave it,, if over an 8th inch thick grind down ta close nuff lol,if going over with another layer of something grind it away alwaYz no matter what kind it is.
Resin infusion and resin content sorenfdk Fiberglass and Composite Boat Building 23 05-17-2011 08:02 AM
Solid Strakes or Leave Hollow? IHTFP Fiberglass and Composite Boat Building 1 04-17-2006 08:49 AM
A sand bagger - strip-planked DanishBagger Fiberglass and Composite Boat Building 28 02-21-2006 04:08 AM
Resin Injection to Repair Hull? c1287n Fiberglass and Composite Boat Building 2 01-02-2006 11:02 PM
how much resin? Lew Morris Materials 3 06-22-2004 07:13 AM
