Old 04-19-2011, 10:41 AM
CatBuilder CatBuilder is offline
Rep: 1316 Posts: 3,040
Best tool for cutting a laminate?
How do you guys cut laminates?
I am worried my low tooth count circular saw or action of my jigsaw will catch on the upper laminate and rip it off.
Kurt Hughes was right about this place.
Old 04-19-2011, 11:23 AM
missinginaction missinginaction is offline
Rep: 417 Posts: 336
If you're talking about taking excess off of edges you would use a laminate trimmer. This is a router bit that any hardware store wil stock.
If you're talking about rough cutting sheets I use a laminate cutting knife. This tool resembles a box cutter (with a very heavy "blade"). The cutter scores the finished surface of the laminate and after you've scored a decent grove in the material you can bend the laminate on the cut and 'snap" it cleanly apart. Any place that sells HPDL will stock this tool.
Hope this helps,
MIA
Old 04-19-2011, 11:33 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
You can buy jigsaw blades with the teeth set the other way.
Old 04-19-2011, 11:39 AM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 746 Posts: 785
Use a 4" diamond saw attached to an angle grinder.
Old 04-19-2011, 11:58 AM
david@boatsmith david@boatsmith is offline
Rep: 50 Posts: 85
You can also use abrasive cutoff wheels in a mini grinder to trim your laminate. I use the ones for steel.
Boatsmith Inc
We Build Your Dreams
(561) 744-0855
www.boatsmithfl.com
Old 04-19-2011, 03:47 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Grit edge blades can be purchased for almost every type of saw, you can get fine, medium and coarse depending on the need. They typically leave a nice edge with little or no chipping.
Old 04-19-2011, 05:25 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
These are slower than the circular blade grits but you will get a nice edge with more control. I suggest these only because you already have experience with jigsaw and know its quirks. The circular grit wheels are also great but require more practise to control.
Hoyt
Old 04-19-2011, 05:26 PM
AndrewK AndrewK is offline
Rep: 338 Posts: 377
Carborandum grit blades for the jigsaw and diamond wheel for the grinder.
Old 04-19-2011, 05:35 PM
Sounds like I will need both the blade for the circular saw and the blade for the jigsaw.
One cut is the bow, which is quite close to the mold and over some extra length of battens. That cut is best done with a circular saw at the depth of the laminate, so it doesn't cut into mold.
The other cut is a little I could grind off the edge and the last cut will be the transom profile later on.
Still not sure how to end the laminate at the transom, but that's in another thread.
Thanks for the advice. I figured everyone would know good ways to do this - and you did.
Old 04-19-2011, 06:45 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,597
I use McMaster -Carr a lot for small quantities of blades discs etc. They have the "grit" jigsaw blades and anything else you might need and service to FL is fast-ususally overnight from Atlanta( normal UPS).
yes, it is a revolution
Old 04-19-2011, 10:44 PM
Brian@BNE Brian@BNE is offline
Rep: 140 Posts: 222
Continuous rim diamond blades (not segmented ones) are the only way to go. You use them dry, no water cooling/lubrication unless cutting rock/ceramic tiles. Best of all they can't cut the user! 4" in angle grinder are very versatile, but a larger size in a small & light circular saw would give you good depth control if required.
Old 04-19-2011, 10:53 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
course cut diamond saw blade in a angle grinder . !!
Making beautiful boats is a passion never a chore !
Old 04-19-2011, 11:10 PM
bntii's Avatar
bntii bntii is offline
Rep: 1073 Posts: 704
Oops- I had thought you were speaking of laminates as in sheet goods like formica.
For glass laminates I have not used much other than the hardened steel cut blades in the Fein for some years.
They do wonders- will cut right through 1/2" of solid glass & will zip right through your hull layup like paper.
They have the advantage of being low dust (they will not throw the dust all over the place and are highly controllable.
In the bad old days I would use a fine cut wheel in a right angle grinder. No more thankfully as they are such a mess..
For me- the Fein is indispensable tool & doing cut work like this is its game.
Old 04-21-2011, 08:40 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
It is just the noise that annoys me. Ear protection required!
Diamond blades work as well, but indeed throw dust all over. Respiratory protection! These are much faster than the Fein.
Also, when the diamond blade stops working in FRP, make a few cuts in stone. This will revive the blade.
Old 04-22-2011, 09:45 AM
westsail42 westsail42 is offline
Rep: 10 Posts: 49
Carbide grit blades. You can pretty much get any kind of blade in carbide grit: sawzall, bandsaw, jigsaw, holesaw.
The one I havent found a good solution for is an equivalent router bit for routing glass laminates, anyone have a suggestion?
Building out a Westsail 42 Ketch
http://on.fb.me/hYZxpC
www.westsail42.com
Tool for recessing foam? shizlenut Fiberglass and Composite Boat Building 8 04-04-2011 02:25 PM
Unique new tool rasorinc Wooden Boat Building and Restoration 4 12-18-2010 05:59 AM
whats this tool Boston Boatbuilding 4 12-21-2009 04:43 PM
Tool Recommendation Please SeaJay Fiberglass and Composite Boat Building 30 06-21-2009 12:15 AM
Recommend a good cutting tool for building boat denniswang Open Discussion: All Things Boats & Boating 9 02-26-2006 10:33 PM
