Old 04-27-2011, 07:56 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Go have a look for DIAMOND TOOL manufacturer . In New Zealand we can get almost anything at all and can get tools specially made to anyshape you want ! All costs but lasts a life time if looed after properly, Have a saw blade for my grinder for more than 10 years and gets used a lot . .
Making beautiful boats is a passion never a chore !
Old 02-08-2012, 05:04 AM
Row 4 Life Row 4 Life is offline
Diamond Tools
Hi,
My husband used Diamond Tooling (http://www.gandtrack.co.uk/products/diamond-products) and got in touch with a company called Gandtrack. They have a range of suitable products and helped us (him) out a lot! It was best that I stayed clear of any tooling!! Hope this helps!
Old 02-08-2012, 06:49 AM
old one !
Originally Posted by Row 4 Life View Post
Hi,
wow that took a long time to get a reply !! as i said diamond blades will last a life time if they are looked after !! glass cutting blades are made to only cut glass and if used for anything else they will be shot in a very short time .
Old 02-08-2012, 07:17 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Welcome to the forum, Row 4 Life.
Was your husband cutting fiberglass laminate?
Those look like excellent cutting tools.
Hoyt
Old 02-10-2012, 06:06 PM
redreuben redreuben is offline
redreuben
Rep: 164 Posts: 352
The continuous rim diamond blade is THE tool for cutting composite laminates, further in angle grinders a 125mm blade will provide mush better directional control than the 100 if your cuts aren't too intricate.
Old 02-23-2012, 01:12 PM
brokensheer brokensheer is offline
Rep: 14 Posts: 108
I use the vibrating multi tool from Harbor Freight at 19.00 its disposable and it works like a charm
Old 02-23-2012, 04:38 PM
Rep: 501 Posts: 1,767
A laminate trimmer or cutting knife work best. They are inexpensive and are designed for that.
Old 02-23-2012, 06:00 PM
redreuben
Rep: 164 Posts: 352
I believe the OP is referring to cured fibreglass laminate, not Formica !
Old 02-23-2012, 06:32 PM
For fiberglass a circular saw with a 40 tpi blade works great for straight cuts, I treat it like wood, jigsaw, router, Saw-alls etc... Bits/Blades don't last very long, and used many teeths. The vibrating tools work great to make small cuts or finish ends.
Tool for recessing foam? shizlenut Fiberglass and Composite Boat Building 8 04-04-2011 02:25 PM
Unique new tool rasorinc Wooden Boat Building and Restoration 4 12-18-2010 05:59 AM
whats this tool Boston Boatbuilding 4 12-21-2009 04:43 PM
Tool Recommendation Please SeaJay Fiberglass and Composite Boat Building 30 06-21-2009 12:15 AM
Recommend a good cutting tool for building boat denniswang Open Discussion: All Things Boats & Boating 9 02-26-2006 10:33 PM
