Old 07-24-2007, 06:11 PM
grady's Avatar
grady grady is offline
Novice
Rep: 70 Posts: 459
Best method to repair stress cracks
Hi everyone, I've been busy stripping my hull of all hardware, trim and upholstery. But now I am prepping for paint and I'm uncertain how to proceed in the mitigating of those tiny little stress cracks. I would think that you would want to open them up to be able to push some thicken epoxy into the area.
But then I think about all that grinding, filling, fairing and priming, I wonder will a good med build primer fill these cracks? And if they do fill with primer will they reappear?
ANY GUIDANCE IS APPRECIATED
THANKS
Fair winds & calm seas
Old 07-25-2007, 01:15 AM
Rep: 2891 Posts: 8,798
First determine if they are really stress cracks. If there is an underlying issue causing the area to flex excessively or some sort of laminate damage, then you'll be fixing the same area again.
You could fill the opened cracks with a high build primer, but you'd be laying down a lot of paint for the average crack. I think this is asking a bit much from primer.
Yep, grind it back to clean, stable material, fill and fair. Sorry . . .
Old 07-25-2007, 07:47 AM
grady's Avatar
Novice
Rep: 70 Posts: 459
Thanks Par, For the quick reply.
Most of these are small, spider type cracks that seem to start in corners. They are all short in lenght and appear shallow in depth. Almost going unnoticed, except of course to me.
One area shows much longer cracks on the gunwale above the rub rail. Approx 6-8" long, this area was hit by sail boat that miss his mooring. There was damage that was repaired close to this area.
Hope to keep the grinding to a minimum, But what tool would you suggest to open up the cracks. I was thinking, maybe a dremel type presicion grinder. As most of these cracks are in tight spots,in or around corners where two or more surfaces come together.
Thanks Again for all your help.
Grady
Old 07-25-2007, 11:07 AM
I usually don't screw around trying to be too neat about it and the edge of a disk grinder does the deed quickly. In tight spots a Dremel (I use a high speed pencil grinder) or Roto-Zip can work. I figure the area needs to be faired anyway, so why bother. If you'd like to be neater, then a Dremel can work, though I've often found this particular tool doesn't have the nuts to do much more then polish jewelry. Don't try to be too neat, the repair needs surface area to stay stuck, so open them up good. You can be neater with your filler applications, to save sanding time.
Old 07-26-2007, 06:38 PM
grady's Avatar
Novice
Rep: 70 Posts: 459
Thanks Par. Yeah I thought I would use the the 4" grinder on the open areas. But I'll have to figure out what tool will work in those tight corners.
Anyway thanks again, And of course there are a couple of other issues, I have some small screw holes where snaps were attached. And I need to fill them. I was thinking about countersinking these holes and filling with an epoxy-cabo sil puddy, They don't seem big enough to warrant a glass patch.
Please advise.
Best Regards
Grady
Old 07-27-2007, 09:04 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
start small
by the sounds of it, the cracks may be just in your gel-coat, id start off with a DA and 80 grit,,sand off the gel-coat and see if the cracks are in the actual fiberglass
Stress cracks around outdrive on 23 footer VKRUE Open Discussion: All Things Boats & Boating 5 07-21-2007 08:44 AM
stress in sailboat hulls bntii Boat Design 2 07-26-2006 06:54 PM
Stress cracks or gel coat damage? see attachment 75HUSTLER Boat Design 2 06-23-2006 09:13 AM
spider Cracks? H20fwler Fiberglass and Composite Boat Building 17 01-16-2006 05:27 PM
Stress Cracks cammo Fiberglass and Composite Boat Building 8 09-26-2005 10:25 PM
