#31
| ...or slow down the speed.....they should only be doing well under 2000 for heavy grinding, I run mine at 1400 with 36 grit.
#32
| Landlubber --what the hell is your avatar, I cant make out what it is , is it a woolly mammoth with a hat on near your bedroom window? I don't know what the hell that is. 4 inch 16 grit 4000 RPM the skill is in your hand not the machine. 16 grit is like self cleaning, like a mud tyre, it self cleans. |
#33
| ...Frosty, have a look here, the "real" Landlubber...poor bugger has no "real" boat, this is what happens when you only have a dinghy, no more ocean boats to play with....don't let this happen to you. http://www.tonmo.com/articles/olsen.php
#34
| I don't know what you are smoking but I would give it up if I were you. Im a sensative boy, I will be having night mares now after looking at those distorted figures. Change your avatar to a crankshaft or something nice, as long as its not a cute kitten or i'lle have to smash my lap top in. |
#35
| Just thought I should follow-up and say that the Zec is the deal. About twice as fast as regular 16 grit disc and no problems chopping up the surface - just hold it flat. One wheel did the whole job too so no lost time changing discs. I did follow with the 36 grit soft pad on buffer to finesse it a little. Not the tool for every grinding application but if you need aggressive material removal this is it. Thanks to all. |
#36
| diamond segment grinding disc Dear CDK: Where do you buy the diamond segment grinding disc? Thanks, Roy |
#37
| Roy, this is the kind of disc designed for cutting relatively soft but abrasive materials like limestone or marble. I bought mine in a department store a few years ago. It came as a set of 3 different discs, the others for ceramic tiles and granite. You should have no problem buying such discs on Ebay.
| grinding welds | alanrockwood | Metal Boat Building | 72 | 10-11-2011 05:44 PM |
| Mercruiser Alpha One grinding noise | pup55 | Sterndrives | 3 | 08-02-2009 04:32 AM |
| love grinding, need design | dockdave | Boat Design | 5 | 06-07-2009 07:05 PM |
| Stringer Grinding help needed | IHTFP | Fiberglass and Composite Boat Building | 10 | 11-05-2008 01:10 AM |
| Ice grinding. | sigurd | Materials | 13 | 12-02-2007 11:50 PM |
