Old 12-25-2004, 02:24 PM
mikkyle mikkyle is offline
Rep: 10 Posts: 4
Bent Trim Piece
Anyone know how to straighten a bent aluminum trim piece? It's about 1" wide X 3/16" or so thick,and 10ft long, and is the trim that the screws go thru to hold the port side Deck/Hull seam on my old fiberglass beater together. It got caught in the garage door spring, and when I opened the door, it put an nice 60 deg bend in it. Its bent on a screw hole, and just wondering if anyone else had to bend back aluminum before. Should I heat it, I have propane and oxy/ace torch, or just try to hammer it gently back? Should I take to a metal shop?
Thanks
Mike
Old 12-25-2004, 02:38 PM
Rep: 1397 Posts: 7,215
If you have the patience it is possible to bend it back cold. I assume it doesn't have a deep crease or is cracked. You'll have to make a jig to bend it on. Sometimes a U channel and a vise can do it . The trick is not to crush the molding. It has a place for a vinyl molding doesn't it?
Old 12-25-2004, 04:07 PM
Rep: 10 Posts: 4
Gonzo, no it is just aluminum and no vinyl. There is a straight piece on each side from where the bow stops curving, back to the transom. Older glass boat made in 1957.
Old 12-26-2004, 09:15 PM
Heating up aluminum is tricky because it doesn't change color. As soon as the surface gets shiny it is about to melt. I suppose that if you heat enough to soften it without getting to the shiny point it may help too.
Home made trim. Original idea? stratus5 Propulsion 0 10-02-2005 06:24 PM
Keel Trim Tab mojounwin Sailboats 6 09-10-2005 11:26 PM
2 piece Vs. 3 piece Hulls image691 Boat Design 12 08-07-2005 08:55 AM
speed & Trim angle curve by maxsurf, hull speed Joe Lu Software 1 11-25-2004 07:37 PM
teak and holly plywood piece modunlavy Boatbuilding 1 03-30-2004 09:09 AM
