Old 10-06-2005, 08:42 PM
IHTFP IHTFP is offline
Rep: 10 Posts: 32
Belly Tank Removal
I have an aluminum belly tank that I need to remove. The tank is sitting between stringers and bulkheads on each end. The tank is foamed in. How do I get the tank out without damaging the stringers and bulkheads? I was thinking of epoxying some wood blocks to the top and then pulling up using come-alongs. Are there eny chemicals that I could pour on the foam to dissolve it without damaging the fiberglass?
Thanks
Old 10-06-2005, 09:23 PM
nero nero is offline
Rep: 112 Posts: 624
Photos?
epoxy fuel tanks Boatbuilding 24 08-14-2008 04:36 AM
Fuel tank inquiries. Hou-Chap Fiberglass and Composite Boat Building 5 03-04-2005 09:02 AM
Gas tank compartment ventilation Washburn Boat Design 4 09-17-2004 02:53 PM
Help with Replacing the Belly Tank in a 25' 72 Sea Ray Bugmanx Boat Design 9 07-24-2004 10:00 AM
gas tank building bushbunny Boatbuilding 12 11-14-2003 11:04 AM
