| Bedding Stringers In replacing the stringers in my 17ft Aquasport I am considering bedding them in 5200 rather than epoxy. The stringers are modified 2x10's treated with CPES and are going back into the original fiberglass sheaths. The sides and top of the stringers will be coated with modified epoxy and the top fiberglass cap installed. I read quite a bit about epoxy hard spots so I thought 5200 may be a better choice for the contact between hull and stringer. |
| It would be a waste of money. Set the wood just above the bottom. If you want to make sure that you are not contacting the bottom you could use a strip of foam to set your stringers in. |
| Jim, thanks for the reply, but I do want to secure the stringers to the hull bottom. I thought 5200 might be a little more flexible than epoxy. Thank you |
| You must have misread this, I do want to secure the stringers to the hull bottom, just thought 5200 would be a little more flexible than epoxy, and possibly a less costly solution. Although at $15.00 a cartridge, it is closing the gap on epoxy. Thanks for the interest. |
| I am willing to bet it would be cheaper (and a lot stronger) to glass them down with epoxy and biax ![]() |
| You dont want the stringers to touch the bottom of the boat because you will setup a stress point on the bottom that will cause all sorts of structural issues. |
In this picture, you will see two stringers (already glassed on top of foam trapezoids), and a bulkhead which is sitting on the foam trapezoids waiting for glass ![]() |
| Interesting, they float on the foam, but are trapped in the fiberglass shell. Originally mine were set on a type of hardened filler, and I assumed they had released because of moisture intrusion. Stringers are never hard fastened to the hull bottom? Thank you both for the replies. |
| The stringers were probably bedded down in Plexus or some adhesive – that’s the way production boat building works. The reason they do it this way is cost – its quick and saves labor, not because it’s the best way. What you see above (while not pretty work) is a better way to install stringers. There are no hard spots, the load coming from the hull is spread out evenly through the fiberglass skin (multiple layers of biaxial cloth) to the stringers. There is nothing secret or ground breaking here. |
| Good information, thank you. |
| Good information! ![]() |
| JR Shine, Where can you get the foam trapeziods? Are they made exclusively for boatbuilding. Also, when installing stringers in a deep V bottom, does the technique change any? Thanks |
| Got a question regarding to bedding the stringers. I know Jimsdale wrote not to place the stringers touching the bottom, understood. But what do you use for filling between the stringers and hull befor you glass them? |
| Bedding/sealing compound help | skiffbuilder | Wooden Boat Building and Restoration | 2 | 03-10-2006 09:35 AM |
| Bedding Fasteners | boatrat | Wooden Boat Building and Restoration | 3 | 04-12-2005 11:51 PM |
| Engine Bedding - 35 Bertram | Jeff - Fazmataz | Boat Design | 1 | 03-21-2005 06:00 PM |
| To do or not to do... All glass stringers | JamesR | Materials | 2 | 10-28-2004 10:37 AM |
| Bedding Aluminum? | GrapeNutsCereal | Boatbuilding | 1 | 07-24-2004 11:19 PM |
