Old 12-31-2010, 11:03 AM
frank smith frank smith is offline
Rep: 154 Posts: 672
Basic fiberglass hull .
What is the easiest method for producing a one off fiberglass hull of about 20' .
Old 12-31-2010, 11:12 AM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
http://www.cyberstreet.com/andre/
Slippery when wet.
www.cheetahcat.com
Old 12-31-2010, 12:00 PM
Rep: 3125 Posts: 9,399
Single skin over a mold of some sort, will be the easiest. You can use foam, though there are much less costly options then the foam core products Steve has linked, plus you don't have to sheath the core twice with a single skin layup, like you do with a core.
Old 12-31-2010, 12:01 PM
Rep: 154 Posts: 672
Nice product, what is the preferred resin to use with it?
Old 12-31-2010, 12:11 PM
Rep: 154 Posts: 672
I have thought that covering a male mold with poly , and stapling a a layer of glass on and wetting out might work. Once cured to a green stage ,additional layer would be added . The worst part of this hole deal would be getting the first layer on. I suppose if it were a multi chine design , then I could make fiberglass panels and staple then on to the mold.
Old 12-31-2010, 03:52 PM
idkfa idkfa is offline
Rep: 66 Posts: 232
How about thin glass skin over coosa board? Turn right way up and tape seams and bulk heads joints? She'll be hard chined unless you got fancy with radius curves, etc.
http://www.dixdesign.com/radmetal.htm
The bead and cove book is complete and in-depth, week+ to grok, maybe better to keep a 20fter simple.
Guess it depends on the design?
ps, never did either method, yet. Plan to do the first.
Old 12-31-2010, 04:14 PM
Rep: 154 Posts: 672
Coosa is an interesting product , my guess is that preglassing foam panels is not new and can be done on site. I wonder if there would be any savings.
I wonder if anyone is using cflex , or dura core anymore ?
Old 12-31-2010, 04:38 PM
It depends on what you want Frank, but I'll assume, possibly incorrectly that by "easy" you also mean inexpensively. If this is the case, then forget about all the fancy foams, honeycombs and man made materials like Coosa, C-Flex, etc.
If I was to build a one off on the easy and cheap, I'd build a set of station molds out of cheap sheet goods (MDF, particle board, etc.) then spring furring strips over it (ripped from the edges of 2x10's) then cover the whole mold with el cheapo foam, just to have something to fair. Once the foam was faired, I'd cover it with heavy plastic sheeting and layup the single skin. I wouldn't staple it to anything, just use light finishing cloth as the first layer, in manageable sizes, then a traditional laminate schedule of knitted fabrics. Once this was finished, I'd fair the hull, paint then pop the hull shell off the mold. The pieces used in the mold could be used for something else (like a cradle or temporary bulkheads) and now you'd be onto the deck and internal structures.
If it was one of my designs, I'd probably incorporate internal hull stiffeners (like longitudinal girders, sole flanges, etc.) into the hull shell layup, but this requires fore thought and planning, which most backyard builds can only dream about.
Old 12-31-2010, 05:20 PM
CatBuilder CatBuilder is offline
Rep: 1316 Posts: 3,040
Now that's the way to do it easy and without spending too much money.
Gets my vote!
Kurt Hughes was right about this place.
Old 12-31-2010, 05:34 PM
Rep: 84 Posts: 661
You can also develop the shapes (sides and bottom ) lay them up on a mica faced table then glass the whole thing together (Chine ,transom and Keel) on a minimally framed jig (So you have room under it) we refer to this as a panel built, it gives a good start on the finishing.
Slippery when wet.
www.cheetahcat.com
Old 12-31-2010, 08:08 PM
Yep, Steve's method is great for a chine hull, though you'll have seams to contend with, you do get to work on smaller, more easily managed pieces during most of the layup. I'm a round bilge guy, so I'd work in or over a mold.
Does anyone have a basic 40' hull file I can use? mwysen Software 7 07-27-2010 08:57 PM
New to Fiberglass, very basic questions... science abuse Fiberglass and Composite Boat Building 32 06-29-2010 11:49 AM
Basic planing hull design RJGoodhead Boat Design 9 04-27-2010 02:19 PM
Restoring a fiberglass hull David55cobra Boat Design 5 12-09-2008 11:21 PM
Basic hull shape question... Keycube Boat Design 6 03-01-2003 09:11 AM
