Old 01-24-2006, 09:00 AM
rturbett's Avatar
rturbett rturbett is offline
Rep: 22 Posts: 139
Balsa filler
On a male mold layup, I have sanded the balsa core to fair. What is your favorite filler to use to "fill in the cracks" before glassing the outer hull? Would you consider laying the glass on a wet epoxy/filler? (I think that would be difficult)
Thanks,
Rob
Old 02-02-2006, 05:45 PM
Rep: 1397 Posts: 7,215
If you fill the cracks with epoxy and silica filler and laminate while it is still soft, you can skip sanding.
filler for scraps okieman98 Materials 4 12-04-2005 02:45 AM
Balsa core "filler" rturbett Fiberglass and Composite Boat Building 3 10-13-2005 08:48 AM
Filler Foam Fat Sam Fiberglass and Composite Boat Building 4 04-27-2005 02:56 PM
Foam and filler JJ£ Boatbuilding 1 10-08-2004 03:25 PM
Wood Filler drewst Wooden Boat Building and Restoration 3 08-29-2004 04:09 AM
