Old 12-28-2005, 05:02 PM
James Maldonado James Maldonado is offline
Rep: 10 Posts: 2
Balsa core vs. foam core
The question has arisen concerning the use of balsa vs. foam core in decks for a mid-size (80 ft.) cruiser-style boat. Is there a formula or some place I can locate info on the deflection and tensile strength between the two? Also, how about the weight differences of these materials?
Old 12-28-2005, 05:10 PM
Deering Deering is offline
Rep: 14 Posts: 219
The manufacturers of the core products (Baltek for balsa) publish engineering data on their products. But it's probably not the core properties that are going to drive strength/deflection on the decks. It's the glass reinforcements that are laminated on the outsides of the core - that's where the load is carried. Similar to an I-beam - the web is the core, and the flanges are the laminate. They work together as a system.
Typically foam can be lighter than balsa, but there's lots of different foam out there.
Old 12-28-2005, 09:20 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Deering is right the manufactures have a lot of info on where too start and are a good source of information both in technique and engineering! Myself I use plastic foam!
Slippery when wet.
www.cheetahcat.com
Old 12-29-2005, 03:10 PM
Rep: 10 Posts: 2
Thank you for the help.
Old 12-30-2005, 02:48 AM
GeoffSChapman GeoffSChapman is offline
Rep: 10 Posts: 37
Spherecore SBC
Anybody tried this product from spheretex? "sphere.core SBC is a newly developed mat consisting of volumised short glass fibers"
We have recently replaced endgrain balsa stiffening in our 10m hulls (fast planing fishing boats) with 10mm in the bottom planes and 6mm in the sidewalls.
It weighs about the same but gives a more homogeneous panel which can take hard shocks without delamination.
see www.spheretex.com
Old 01-02-2006, 05:51 AM
zerogara's Avatar
zerogara zerogara is offline
build it and sail it
Rep: 64 Posts: 142
Spheretex & spherecore
http://www.pirogue.com/process.htm
http://www.epotex.se/page/140/140/59/61
Here are a couple of sites I've found with pictures of building with spheretex products.
The one is the Backman 21
KoZ
Old 01-05-2006, 08:24 PM
Alan M. Alan M. is offline
Rep: 140 Posts: 176
The strength of the core IS important. It is the core which keeps the laminates apart. Balsa (end grain) is much stronger in compression and sheer than any of the foams. To achieve similar rigidity to a balsa core in a panel using a foam core will require a thicker core, and /or thicker glass laminates. The results are that a balsa cored panel can be lighter for a given stiffness than a foam cored one.
Old 01-05-2006, 08:37 PM
Rep: 84 Posts: 661
Compressive strength? That is precisely what is wrong with balsa in highly stressed areas it imparts the impact to the inside laminate! Hard to beat a “ductile foam” like airex or core cell ..Stiffness! Well that is great but taken to the point of yield a different story you have what ; failure better to give a bit and keep the panel intact!
Slippery when wet.
www.cheetahcat.com
Old 01-05-2006, 11:32 PM
Rep: 140 Posts: 176
There is a difference between stress and impact. In a stress loaded area it is important to keep the laminates apart, for rigidity. In an impact situation it really depends on how large the impact is : balsa will resist damage from small impacts better - it will support the outer laminate better than foam will. In large impacts it's true foam will transmit less of the force to the inner laminate, but the outer laminate and core will suffer greater damage.
Old 01-06-2006, 06:37 PM
Rep: 140 Posts: 176
The reason we use cores of any type is to increase stiffness, without adding weight. The desired stiffness of a panel could also be acheived by a solid layup, and often is, but at far greater weight than sandwich construction. So what we are looking for from a core material is the best possible panel stiffnes per weight. Panel stiffness comes from the cores ability to resist compression and sheer, and balsa is superior to foam in these properties. It is denser, but to get the same stiffness from a foam core requires a thicker laminate, or a thicker core, or both, and results in a heavier panel. ATL in Queensland make Epoxy/balsa/epoxy panels, as well as epoxy/foam/epoxy panels. They have comparitive data for them on their website. www.atlcomposites.com.au
Old 01-08-2006, 06:48 PM
RealityBoatCo's Avatar
RealityBoatCo RealityBoatCo is offline
Rep: 10 Posts: 93
I sure wish that site could tell me something, all I get is an entry page and can't go anywhere from there. www.spheretex.com
Old 01-09-2006, 03:43 AM
zerogara's Avatar
Rep: 64 Posts: 142
http://www.spheretex.com/en/1.html
Try this to go past the entry graphics level
Old 01-09-2006, 06:36 AM
Rep: 700 Posts: 3,208
The problem with Balsa is every so often the boat has to have EVERY fitting ect removed to reseal the item.
If water gets to the core it rots. Same as with Tiawan Tubs when the GRP paint is puncured and not resealed. WOOD ROTS.
The coat of a plastic core (nadiacore) or airex should be considered as insurance , against total failure in time.
FAST FRED
The cost of a plastic core (nadiacore) or airex should be considered as insurance , against total failure in time.
FAST FRED
Old 01-09-2006, 12:02 PM
Rep: 10 Posts: 93
Thanks that worked great.
moldless foam core High Performance hull wetRat Fiberglass and Composite Boat Building 7 01-27-2006 04:34 PM
Selecting foam core TomE Materials 14 01-07-2006 05:18 AM
building with PVC core foam signum Fiberglass and Composite Boat Building 3 11-26-2005 08:02 PM
Balsa core "filler" rturbett Fiberglass and Composite Boat Building 3 10-13-2005 08:48 AM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 07:00 PM
