Old 01-09-2006, 03:41 PM
buckknekkid's Avatar
buckknekkid buckknekkid is offline
Rep: 37 Posts: 345
[quote=FAST FRED] Same as with Tiawan Tubs when the GRP paint is puncured and not resealed. WOOD ROTS. we are waist deep into the cockpit refit right now, trust me it ROTS!
Can anyone spare any gas today for a hamburger on Friday ???
Old 01-09-2006, 06:01 PM
Alan M. Alan M. is offline
Rep: 140 Posts: 176
No denying that wood, as an organic material will rot in cases of neglect. I would suggest that as a core material it would take more than just scratching the paint off it to allow water to enter though. Also, most end-grain balsa used for coring has a coating of epoxy on it, and is made of relatively small "cells" glued together, which dramatically restrict the movement of water, which being across the grain, is very slow to start with. As for having to routinely remove and re-seal deck fittings, it's a better practise to remove the core from the deck and replace it with solid glass/epoxy, where ever you attach deck hardware, regardless of what the core material is.
Old 01-09-2006, 06:04 PM
Rep: 37 Posts: 345
I believe the reference was directed to Taiwanese boats, of which some I have painted were nothing but foam and paint.
Old 01-13-2006, 02:18 AM
Julian Carrick Julian Carrick is offline
Julian Carrick
Lantor Coremat is better than Sphericore and Upica as it is made using short fibres and therefore breaks down quicker and releases the air better. If you are doing compound curves XM is even better as it drapes in all directions without creasing, takes 10% less resin and has good pick up strength when wet out on the bench.XM is also getting a good reputation as a print through blocker if you have a lot of heavy wovens in the hull
Old 01-20-2006, 03:30 PM
Rep: 37 Posts: 345
hope this works
Old 01-20-2006, 11:24 PM
Rep: 140 Posts: 176
Yep, it works. Shows end grain Balsa to be an excellent core material too, doesnt it?
Old 01-21-2006, 03:09 AM
zerogara's Avatar
zerogara zerogara is offline
build it and sail it
Rep: 64 Posts: 142
I believe that where balsa suffers most in comparison is where a localized impact is severe enough to cause damage to the core and delamination. All types of foam will stay in tact in the surrounding areas where balsa will delaminate in a much wider area.
Thanks to buckknekkid for the chart, one with some equal layers of frp would be a good comparison as well.
Spheretex sphere.core SBC has a comparative analysis of 4 composites where they show how they are on par with balsa but have better bonding qualities than balsa as the problem with bonding dissimilar materials is their advantage.
http://www.spheretex.com/pdf/Sphere.coreSBC.en.pdf
Old 01-21-2006, 04:37 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
I just received a free package of samples from spheretex and will compare with divinycell. Have you did some testing?
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 01-21-2006, 10:12 PM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
I had A 10 metre sail cat that used 6mm coremat in the round bilge sections of the hull & topside panels[she had a spray deflecting chine & 1 other clinker style chine in the topsides- these seemed to help stringer the topsides & formed landings for bench & bunk heights], the decks were foam cored.During seven years of ownership, 2 of which in daily use, dingy knocks ,wharves etc left nothing but light gelcoat scratching.Also sailed well, at 2.7 tonne not outrageously heavy for a 10m cat with bridgdeck cabin. She was molded by Endeavour Yachts for Beach Marine[both gone] & appeared to have been designed for this style of construction & IMO a terriffic advert for success of it.Jeff.
moldless foam core High Performance hull wetRat Fiberglass and Composite Boat Building 7 01-27-2006 03:34 PM
Selecting foam core TomE Materials 14 01-07-2006 04:18 AM
building with PVC core foam signum Fiberglass and Composite Boat Building 3 11-26-2005 07:02 PM
Balsa core "filler" rturbett Fiberglass and Composite Boat Building 3 10-13-2005 07:48 AM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 06:00 PM
