| Bait tank/ holding tank fabrication question I am planning on building a bant tank & holding tank across the transom of my boat. THe overall width is 102". I am thinking to have 2 30~40 gallon soze tanks on each ends--port & starboard side of the transom and the mid section to have a live well/holding tank. All of this will be mounted on the swimstep as well as have u-brackets that will fasten it on the transom as well. What would be the best material for this project? I am thinking waterproofed balsa laid with fiberglass on the exterior for uniform apperance as the hull. Any insights & directions would be greatly appreciated. Thanks in advance. JW |
| Are you refering to a sewage holding tank? If so, it needs to be up to Federal standards.
__________________ Gonzo |
| One day I was watching Ship Shape TV and he took a laminating table ( a piece of plywood with formica over (counter top) and waxed it. then he took woven roven or some heavy weight glass layed out across the table coated it with epoxy. Allowed it to dry, peeled it up and rolled it into shape. At the time I was in the process of building my flats boat and was in need of some bait wells, I tried it with a medium weight cloth with mat on one side and it worked out well. In your case your looking for something a little larger than a bait well but don't see why it would not work for you. just remember that corner should be round and the water should circulate counter clockwise unless you are on the other side of the earth. Also I put the mat to the inside for an smoother surface on the inside. |
| hmm. that sounds pretty good/convenient for a smaller tank, but the one I am planning is much larger and not sure if that is gonna be structrually sturdy enough(??). Wouldn't be too brittle with just the woven cloth alone even if I put additional layers of heavy cloth? Here is a rough diagram(it's really not to scale) of what I am thinking. Each bait tank will hold at least 40~50 Gallons of water so there will be enough weight and pressure from the water there.. I would like to get this thing as light weight as possible without compromising the structural strength of it. Any ideas? BTW. I agree with you about the rounding of the edges on the inside of the well with clockwise water rotation. I am thinking of rounding the exterior corners as well. |
| Have you considered what adding 400-500 lbs to the aft end will do to the boat's trim. If the panels are flat like in the drawing, Baltek makes balsa 4X8' already glassed. You can cut them and join them with fillets and tape on the edges. Another thing to think about is that amount of water free moving. Without baffles the tanks will have to be very strong and have lids, hinges, locks, etc. that can handle the loads.
| With the wight of water your looking to carry any tankage will be under 2lb per sq ft of surface and hardly count. FAST FRED |
| very good point gonzo. and as to the tank being brittle you must be refering to polyester resin. epoxy won't get brittle and as far it holding up without adding any extra glass should not be a problem. in my experience if you run your water in a clockwise rotation your fish will die. |
I thought clockwise water rotation was suppose to be ok.. but I am an amatuer with this.. thanks for the correction. |
| My biggest concern is getting caught offshore in a fast squall that causes the waves to hit at the bait wells and fill if the tops are at deck height. They can also provide the full area of their bottoms to a wave slamming up the bottoms . No course or speed will stop them from pounding the bottoms. Putting a 45 degree angled filler piece would stop a lot of the upward slamming action. Enough? I really can't say. Lots of sea conditions to think of with a loss of all power. Another is to mount the tanks with break away pins if things get scary. Let the tanks go and come home safe and with a complete transom. |
What if I decrease the size of the bait tank to ~15ga. ea. the center "livewell" is essentially a box to put my catch. I thought it would be nice to have some water running through it to keep'em fresh, but I know weight is definitely an issue. After reading cyclops's post, RE: "..making a break away pin" I am even more scared/hesistant to do this.. It would be a nice feature for me to hve on my boat, but don't want to risk my life in doing so. I am very new to fabricating stuff for my boat. I am currently making a hardtop for my vessel and it is coming out pretty good. And since I have some fiberglass fabric and resin leftover, I thought I would bang out an additional project this winter.. WOuld a 8'x2'x3'(wxdxh) box with 15 gallons of water on each side be that dangerous to mount on the swimstep? Thank you for your insight and any expert opinion(s)/advise. |
| correct me if i am wrong but thats about 360 gallons of water. thats quite a bit. |
| Back to my original concern of filling the tanks in a squall. 8 x 3 x 2 = 48 cubic feet x 64 pounds for each cubic foot of saltwater = 3,200 pounds on the platform and brackets attached to the transom. It will pull the stern down till volume and weight is satisfied. How low? Can not even start a guess. You have some serious engineering to do. |
I AM NOT PUTTING 48CUBIC FEET of water!!! 8x3x2 is just the overall dimension of the entire box. Each ends will hold ~20Gallons of water making a total of 40 ga. at the most. The center portion is just an empty box. Now is 40 ga. that's approximately 320lbs of water weight which is in concern. |
| epoxy fuel tanks | Boatbuilding | 24 | 08-14-2008 04:36 AM | |
| Belly Tank Removal | IHTFP | Fiberglass and Composite Boat Building | 1 | 10-06-2005 09:23 PM |
| Builtin GAS tank question | ebb | Sailboats | 0 | 05-31-2005 12:27 PM |
| Polyethylene holding tank | Terry | Materials | 2 | 03-16-2004 11:19 AM |
