Old 02-06-2007, 08:34 AM
rturbett's Avatar
rturbett rturbett is offline
Rep: 35 Posts: 139
"bagging" results
Can someone let me know what the surface of a vacuum baggged hull looks like when the bag is removed? Are there ridges of epoxy that need to be sanded down, or is it smooth and ready for finishing?
I just finished glassing the outer layer of a glass /balsacore/glass hull, and I wrapped the hull in heavy plastic wrap to hold it to the mold. On removal, there are ridges built up in the creases on the plastic. They sand off easy enough, but it is a lot of extra work that I wouldn't mind getting rid of, if vacuum bagging leaves a totally smooth surface.
Thanks in advance for your input.
Rob "I think I'll go sand now" Turbett
Old 02-06-2007, 11:13 AM
Phil Locker's Avatar
Phil Locker Phil Locker is offline
Rep: 49 Posts: 84
Quick answer: it depends
If you are careful with your peelply & breather placement, and use a stretchy bagging material, you shouldn't end up with an any resin ridges on the work piece. Especially with large flat surfaces like a hull.
Occasionally on foils, which are compound curves, you end up putting in pleats etc into the peelply, or you might have areas of the bag that can't suck down tight into a deep recess, so there might be some minor resin bridges, but nothing significant.
Phil
Competition Composites Inc. / Phil's Foils
www.fastcomposites.ca
Old 02-08-2007, 04:01 PM
rturbett's Avatar
Rep: 35 Posts: 139
Thanks Phil,
Do you have any experience with West's Microlight filler?
I've used 403 for everything. I'm wondering if the 410 would be good for a few spots on the side of the hull.
Thanks again,
Rob
Old 02-08-2007, 07:05 PM
Rep: 49 Posts: 84
410 is great stuff. Easy sanding. They caution not to use it under dark colours (or in other situations where it is exposed to heat). Only for use with epoxy, not polyester/vinylesters
CMD "project Zeus" VS VOLVO "IPS" gerard baladi Pod Drives 13 09-10-2007 09:23 PM
Westlawn ? "Lite" versus "Module 1" MikeT Education 2 10-10-2006 12:13 PM
"Free" 3D modeler "similar" to Rhino CGN Software 0 05-14-2006 10:56 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 02:03 PM
"Propeller pockets" or "Tunnels" 67-LS1 Powerboats 24 04-16-2004 05:08 AM
