Old 01-04-2005, 12:57 AM
lakerunner lakerunner is offline
Rep: 10 Posts: 48
Back to work .. Hole size in question...
Ok holidays are over and springs around the corner . Half to loose 20 lbs..
and get the lead out. QUESTION..... Hole in the upper topside . approx. 16'' in dia. By the time it is cleaned up .It has a foam core, Can I Fix this with a solid lay-up of frp or should I replace the core.. Is there a size of hole that would determine replacement of the core? Its a pretty good size hole . If smaller I would fix with just a lay-up
But I'm in between with my decision. So I must ask .
THE BOAT.......... 24'' Runabout ski boat- Recreation
THE HOLE.........Approx 16'' Dia. Front upper topside just above waterline about 3'' And about 5' Back from Bow.
Simply not sure................Any advice would be appreciated
Old 01-04-2005, 01:29 AM
Richard Petersen
I will not let you leave the foam out.
Old 01-04-2005, 01:59 AM
Rep: 10 Posts: 48
Thanks Richard . Instincts tell me the same . Thanks for all the insomniacs out there
who Knows I 'm awake waiting for an answer.
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
Back to work in the morning... Sean Herron Boat Design 0 01-18-2005 12:03 PM
I/O to Inboard Conversion; DWL Question MDuff Powerboats 7 11-23-2004 05:04 AM
