#121
Alright, from now on. I command that you put all materials that you are going to spray in a bucket of warm water 100 degrees before you--even--think about using it. ![]() I bet you like working in 30 degree weather.....hahaha
__________________ Who Said That?..................... |
#122
| Guys, the high build is for people that are too lazy to fare and prep the surface correctly. My surfaces are fared and sanded to 240 before I roll and tip 545. I roll two coats of 545 before I sand. 545 is soft and sands easy with 325. You need to use the brushing Reducer, just treat the 545 the same as the top coat. Except it's a 1 to 1 mix with less (or none) reducer. You are much better off rolling the 545 even if you spray the top coat, because you can build a good heavy prime base quicker. Just remember that how you finish the 545 determines how your top coat will look. Buy stocks in 3M! |
#123
| What is he doing?????????????????????? Kaptin-jer:What is that, are you sand-blasting something....and what is that big blue thing.......pressure washer?
#124
| What are you talking about?? |
#125
#126
| its a grinder heh ![]()
__________________ hehe ,,,,,Jim------> |
#127
| The software in this forum allows you to zoom in on the pictures. Try it. You'll answer your own questions. When you can make out the symbol on the hat you are close enough. |
#128
| when i use that zoomy thingy,,,i have ta put post-a-notes on my moniter,,,it always seems like ya eyes are followin me kapt. ![]()
#129
| ...and you better belive it...I'm watchin' you. |
#130
| well they do say when ya want to learn from the best,,ya need to watch em close hehe ![]()
#131
| Awlgrtip Paint: Wow, Nice paint job. brush and tip? or spray....... Question: how are you supposed to paint with those stilts holding up the boat? Oh, by the way, I can't zoom..... ![]()
#132
| roll and tip |
#133
| Theoretically, You're not supposed to build with primer Kaptin-jer, earlier you said that you roll two coats of 545 because it's softer and sands easy. Theoretically, it has been my understanding that one should not try to build a surface layer with a primer, simply because it is softer and more maleable than the structures surface i.e. boat hull itself. It is this softer quality that makes the primer inferior in impact resistance. Thus, if you crack the paint, and it is easier to do with a soft primer substrate, you get more cracking and peeling in the future. Additionally, I was under the impression that primer should, and this has been my practice, mostly sanded off, with it's only purpose to fill micro scratches, not imprefections. I recall your saying that some guys use 545 because they don't pay enough attention to fairing their boats, I'm not saying you are part of that group. I was just wondering if, upon reflection, you still endorse using two coats of any primer, and, if you do, how much do you leave. ![]()
#134
| 2 coats are fine,,and primer is ALSO used to give a uniform shade and color to the boat before top coat. if you sand most of it off,,you'll use twice the top coat to get a uniform top coat color. in fact awl-grip says 2 or 3 coats are fine.
#135
I'm a little testy because the Panthers are losing, sorry |
| Joined effort for knowledge sharing | Arvy | Boat Design | 7 | 03-18-2007 04:16 AM |
| CFD background knowledge | josch | Software | 12 | 01-04-2007 09:36 AM |
| awlgrip help | bettysmithers | Fiberglass and Composite Boat Building | 4 | 10-12-2006 03:53 PM |
| Course for boats knowledge? | ale2006 | Education | 0 | 01-03-2006 12:33 PM |
| Knowledge needed on composite boatbuilding | ethan1007 | Fiberglass and Composite Boat Building | 4 | 11-09-2005 09:57 AM |
