  #556
Old 06-21-2009, 09:50 PM
Rep: 527 Posts: 792
Akzo-Nobel has a division in China, so there should be no problem getting Awl-Grip in China.
Jimbo
  #557
Old 06-23-2009, 03:29 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Hong Kong only as of date....they can supply to China but not with stock.
  #558
Old 06-26-2009, 09:07 PM
expos45 expos45 is offline
Rep: 10 Posts: 2
wetsanding/polishing/buffing awlgrip after spraying?
Hi all,
I just completed the deck of my Westail. I used Oyster White Awlgrip. It came out really good...lots of shine, depth, etc....except for a few places where i have some runs...maybe 3" across in a couple of places. I also have a dull "stripe" where it looks like I forgot to spray. Trouble is, I don't have enough paint to respray so I was hoping I could sand, polish and buff out the couple of drips. I have enough paint to mask off the areas, sand it down, and do a touchup respray. Anyone have any insight?
The paint was put on 30 hours ago. Thanks!!
  #559
Old 06-26-2009, 10:50 PM
Rep: 527 Posts: 792
You have two options:
One is to sand and buff the runs out and the other is to sand the runs out then re-paint only the sanded run spots then (after cure) buff off the overspray left by re-painting the spots.
It would take at least 2000 words to adequately describe either one of those processes in detail to a novice, and you would still need a very practiced hand to successfully pull off either task.
If the runs have not 'solvent popped' (have little tiny gas bubbles in them), then either option is still open to you. If solvent popping is present, then only the sand/paint/buff method will still work.
The sand and buff method definitely takes more skill, both with the sander and the buffer. The sand/paint/buff method is easier but does involve some re-painting.
Either way, the most important agenda item is to get the run area truly flat again, so that a 'ghost' of the run will not be visible in the final finish. Many pros scrape their runs off with a new razor blade with a rapid side to side motion that makes the uninitiated wince and yell; but it works!
I'd recommend sanding with 320 or 400 grit abrasive using a rigid block and careful hand so as not to go through the paint, re-shoot the spots with a small detail gun (DO NOT try this with a full size gun!) , perhaps follow up the paint application with a 'melt down coat' of highly reduced paint, then buff of the resulting overspray after cure.
If all this sounds like gobbledygook to you, then this is probably not a task you can pull off. You may be able to find a car painter who'd be willing to help out; they do blends all the time. Tell him to do a 'solvent blend' of the spots. He'll likely know exactly what that means.
Jimbo
  #560
Old 06-26-2009, 11:25 PM
Rep: 10 Posts: 2
Thanks for the reply Jimbo.
I don't have any solvent popping. No bubbles, etc. I was reduced down to about 35%.
I'm familiar with wetsanding, polishing, buffing...but not with a polyester lpu. I think that I'll take your advice and go the route of touch up spraying. Thankfully I have a detail gun to use.
For the issue of overspray, if I razor the drip down, sand to 400, and mask/paper off the surrounding areas, I'll be left with a thin stripe where the taped area that I'd have to polish and blend.,is that the overspray that you mention, or do you mean I would touch up the surrounding area without masking off the nonrepair areas?
  #561
Old 06-26-2009, 11:42 PM
Rep: 527 Posts: 792
There really should be NO MASKING! If you mask anywhere within a foot of the outer limits of the blend, you are completely defeating the purpose of the blend, and will never achieve a blend at all. If you want to mask adjacent surfaces that are not the subject of the repair, then go ahead, but you could just as easily wipe them all down with denatured alcohol immediately after spraying to get rid of the tiny amount of overspray that might fall on them.
But definitely NO MASKING around a blend!
Jimbo
  #562
Old 07-08-2009, 08:42 AM
grady's Avatar
grady grady is offline
Novice
Rep: 70 Posts: 460
Progress Report
Just wanted to post an update almost done, should splash tomorrow With any luck and the blessings of the weather GODS).
I've posted some new pic's in my Gallery, (Grady's gallery) or search with keyword awlgrip.
Fair winds & calm seas
  #563
Old 07-09-2009, 03:28 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
Grady, all the best wishes & weather for the launch, looks terrific mate, from Jeff.
  #564
Old 11-25-2009, 08:15 PM
jorge perez's Avatar
jorge perez jorge perez is offline
Rep: 10 Posts: 2
spraying awlgrip
someone told me to mix awlgrip and put it inside the fridge and paint the next day can someone help me please
  #565
Old 11-25-2009, 09:00 PM
afrhydro's Avatar
afrhydro afrhydro is offline
Rep: 245 Posts: 243
you can do that for some paint thats left over and stop in from cureing over night that way and re spray it in the morning but thats only for touch up or a one time deal
the instructions for mixing are on the can just follow what it says
  #566
Old 11-30-2009, 07:41 PM
grady's Avatar
Novice
Rep: 70 Posts: 460
Some of the key points to a successful paint application lay in the visconsity of the paint mix, and the amount of reducer in the mix. All in consideration of atomization and flow. (KEY)
Not sure what info your getting but cold paint is not going to help. I have heard that awlgrip will have troble curing below 55 degrees but only for short periods of time unless you container is completely air tight
Hope that helps
  #567
Old 12-01-2009, 05:05 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 572
HY guys thought I would surface for a sec. and remind you'all who started that rummor. Fond memories of a colleague that has not posted for over a year. I personally would not use Awl Grip that has been slow curring in a fridge. Not with all the contortions we all go through to get the right consistency for whatever app we are doing (spray or roll and tip). If you have a little left over chalk it up to experience and adjust your mix quantity next time 'round.
Over the years I have spent nearly all of my money on boats, beer, and women. The rest of it I just wasted.
  #568
Old 12-01-2009, 06:45 PM
Rep: 10 Posts: 2
thanks for the info,i also want to know how many hours afetr primer is apply i can wait to spray paint awlgrip
  #569
Old 12-01-2009, 07:03 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 572
You guys are sucking me back in.
You need to sand the primer before top coating. That should answer the drying time question
  #570
Old 12-02-2009, 01:02 AM
Rep: 418 Posts: 777
I miss that Texas transplant
Joined effort for knowledge sharing Arvy Boat Design 7 03-18-2007 04:16 AM
CFD background knowledge josch Software 12 01-04-2007 09:36 AM
awlgrip help bettysmithers Fiberglass and Composite Boat Building 4 10-12-2006 03:53 PM
Course for boats knowledge? ale2006 Education 0 01-03-2006 12:33 PM
Knowledge needed on composite boatbuilding ethan1007 Fiberglass and Composite Boat Building 4 11-09-2005 09:57 AM
