Old 04-27-2005, 02:56 PM
phillip phillip is offline
Registered
Rep: 10 Posts: 25
Attention Newbies!!
Looking for hints for working on fibreglass vessels. Here is one. Get yourself a set of tapered drillbits. Save yourself tons of time and frustration chasing around fasteners while working by yourself. Well ! If that was a coffee break, it's over. Back to chasing some more fasteners.
Phil
Old 04-28-2005, 03:27 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Hey Philip, Since this is a forum for exchanging ideas without charging money for them, may I respectfully ask you to insert one of your drill-bits where they belong?
Yokebutt.
Old 04-28-2005, 07:05 AM
Registered
Rep: 10 Posts: 25
If I had a set of tapered drillbits it is unlikely I would now be the world record holder for actual time spent installing three pad eyes with backing plates. I apologize if I offended you or anyone else on the forum. So much to learn....So little time.
Hey! If your still up? Is 5200 or polysulfide prefered bedding compound. (topside)
Phil
Old 04-29-2005, 05:46 AM
Boatbuilder
Rep: 15 Posts: 545
Sorry mate, thought you were advertising something. I'd avoid the 5200, it's a little bit too good, polysulfide should work allright.
Yokebutt.
Old 04-29-2005, 07:37 AM
Registered
Rep: 10 Posts: 25
Thanks: My learning curve has taken off with the help of this forum. I am using the thread search more. Trying not drive the members crazy with duplicate posts. The great thing about learning is you never stop.
Phil
Old 04-29-2005, 12:21 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
ah, and the more we learn the better we realise how little we know
Old 04-29-2005, 12:56 PM
Marco Walsh Marco Walsh is offline
>Yokebutt.
Too good? Too good for what?
Phillip, if you want those pad eyes to stay put and not leak -- for years -- 5200 would be a good choice for a bedding compound. If you plan to take them off in a few weeks, then maybe the polysulfide might be a better choice.
Some people think that harware bedded in 5200 can't be removed. This is not true, it can be a little difficult, but certainly doable.
My experience has shown 5200 and other polyurethane caulks (such as Sikaflex) to be an excellent bedding compound, especially when considering longevity.
Best,
Marco
Old 04-29-2005, 04:35 PM
Registered
Rep: 10 Posts: 25
The pad eyes have gaskets and are bedded with 5200. I used the poly on the mooring cleat and hatch hinges.I bedded the keel in 5200. I am thinking about the possibility of mixing a little colloidal silica with some black 5200 or sikaflex to fair out a small keel lip. The bottom was done last summer in vc17. The 5200 seems to stick to everything else, so why not vc17? P.S. I think the poly may setup a little faster. Does on your good clothes anyway.
Thanks Phil
