Old 06-28-2011, 09:21 AM
phil32 phil32 is offline
Rep: 10 Posts: 16
Attacking deck
Restoring this 11' tender for my daughter. After trying to remove the deck with no luck we cut the floor out to remove the water soaked foam. Now
I am looking for the best way to attach the plywood and reglass the floor.I have made 4 webs 3/4" wide to attach to the hull with PL5200 and will glass them in. Anyone have a better idea? Also any suggestions on best way to repair this mess previous owner tried to repair.
Thanks, any help would be greatly appreciated
Phil
Attacking deck-boos-boat-006.jpg  Attacking deck-boos-boat-003.jpg  Attacking deck-boos-boat-005.jpg
Attacking deck-boos-boat-007.jpg  Attacking deck-boos-boat-010.jpg  Attacking deck-boos-boat-011.jpg
Old 06-28-2011, 11:40 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,684
On my small fishing boat, after removing the old and digging out the foam, I just put the new ply on top of the old deck, using the old deck as "flanges", more or less. I glued and screwed it down, covered it with chopped strand mat and gelcoat, which left enough texture for non skid and "webbed" it with a little paint splattered out of a paint brush to blend it all together and look good. It raised the deck 1/2" and left a gutter around the edges which was excellent for draining water back to the bilge pump.
Old 06-28-2011, 07:03 PM
Rep: 3125 Posts: 9,399
A 3/4" flange is a mighty small amount of bonding area for the new deck and it appears you've cut through some stringers there as well. Make sure it's well tabbed, to the hull shell, or it'll break out.
Old 06-29-2011, 10:44 AM
Rep: 10 Posts: 16
Par,
Once again thank you for your guidence. I have enclosed a photo of some webs i fashioned to tab to the hull for some strength and attach the deck to. My question is given your concern would it be better to run and tab in a long stringer down the keel and then use the web across.
Again thank you for your help
Phil
Attacking deck-boos-boat-014.jpg  Attacking deck-boos-boat-003.jpg  Attacking deck-boos-boat-005.jpg
Old 06-29-2011, 01:54 PM
If well supported and tabbed, a piece of 1/4" plywood would do fine. A couple of athwartship braces as it appears you've made, well tabbed to the hull shell will prevent flexing of the sole. The plywood tabbing should be a minimum of 4" on each side of the seam. Bigger is always better with tabbing and I'd recommend at least 2 layers of biax tape for the tabbing. Weight is also a consideration so don't go crazy with 3/4" plywood and 2x4's.
Old 06-29-2011, 11:20 PM
Rep: 10 Posts: 16
Par.
Thanks for the athwartship reference, it helps when you know the terms.
Old 07-08-2011, 09:26 AM
Rep: 10 Posts: 16
Attaching plywood to the deck
Par,
Thanks to your guidence I have completed the tabbing and am ready to move to attaching the plywood on the deck. We have a local fiberglass mfg and they supplied me with some around 32oz woven glass 60" wide. There is enough to do 2+ layers that may be an over kill. Would you kindly give me a suggestion as how is the best way to attach the plywood to the existing fiberglass. I can glue and screw to the new wood but dont know the best way to attach to what is left from the demo. I have 2 1/2 " on each side and 13" in the stern and 9' in the bow of existing fiberglass.
Best regards
Phil
Attacking deck-boat-tabbing-013.jpg  Attacking deck-boat-tabbing-011.jpg  Attacking deck-boat-tabbing-010.jpg
Old 07-08-2011, 12:07 PM
Sweet God, 32 ounce roving? Who told you to get that stuff?
Old 07-08-2011, 12:09 PM
Rep: 10 Posts: 16
thats what they suggested for the strength
hard top / deck for sale - styrofoam flotation under Pressure Treated plywood deck WickedGood Marketplace 3 01-17-2011 08:27 AM
engine room ventilation inlet - height above deck/ which deck expedition Boat Design 5 06-16-2009 06:34 PM
What's under my deck??? hapaboy Boatbuilding 4 10-22-2006 05:04 AM
Want to replace old Mako 19 deck with a "Flats boat deck" - am I crazy or what ! dan Boatbuilding 4 09-24-2002 03:48 PM
