| Attaching foam to a mould I would like to know the alternative ways of attaching foam to a female basket mould. I am aware of screwing through the stringers from the outside. Has anyone used Raptor polymer nails or staples from the inside? If so, how do you can the nails/staples to remove the assembly from the mould? Thanks Brian |
| The fastest is to simply sew the foam. We used to build in Airex , and would heat the foam a bit so it would contour to the basket easily. A big needle with a fellow outside to push it back in works really fast.The person inside can see the wood . After the outer skin is laid up , the plug is rotated up right and placed in a simple form to keep the hull shape. The strings were slashed with a knife and the plug simply lifted out. WEAK string , heavy thread (should you miss some cutting loose) will breaK , RATHER THAN TEAR THE CORE MATERIAL. Quick and safe , if you have a helper. FF |
| Attaching a Steel to Aluminum | Hotel Lima | Metal Boat Building | 10 | 01-09-2008 04:01 AM |
| attaching the deck to the hull | bluemarble | Wooden Boat Building and Restoration | 21 | 08-21-2006 08:07 AM |
| Attaching Fittings to Carbon Mast | granite | Fiberglass and Composite Boat Building | 6 | 08-20-2006 11:01 AM |
| Attaching stringers to transom? | mikkyle | Fiberglass and Composite Boat Building | 3 | 12-13-2004 03:21 AM |
| Attaching rubrails, gunwales etc | Matthew | Fiberglass and Composite Boat Building | 3 | 07-21-2004 08:44 AM |
