| ya Beanzy,, i use 24 or 36 grit,,, but for guys just starting,, i figure 80 is bout "middle grounds" hehe ![]()
__________________ hehe ,,,,,Jim------> |
| Ya'll ever use one of those big (I think) 9" flex disc that looks like a waffle? It has maybe 1/16th inch openings and it coated with a semi-rough dark colored composite. I use it to rough up a surface, and being that it goes in a drill, it makes quick work or just about any surface.
__________________ Danny |
| never used those,,,,,,,i dont think,,,,,nope,,. sounds cool tho.
| The nine's are for floor edgers. I think you can get them down to a 6 grit? Check equipment rental places. The waffle type are called sanding screens. I use a belt sander with 80, 40 makes it a bit hard to hang on to and I have striped the drive drum a couple of times using coarse belts. The 80 takes longer, but it is not as much work in the long run, and you get done quicker, not taking as many breaks! And the coarser the belt, the more it costs! There are some wide plastic squeegees in the wall paper dept at Lowes. You can spread it smooth and the resin will come right off when it sets! Lowes has a brand of abrasives called "Gator", they are not high priced and I have been very happy with the quality! |
| trouble with polyester resin | restornator | Fiberglass and Composite Boat Building | 2 | 07-30-2008 04:50 PM |
| Polyester resin and plywood | Whale1 | Fiberglass and Composite Boat Building | 4 | 01-22-2008 08:30 PM |
| Polyester vs epoxy resin | OGM | Fiberglass and Composite Boat Building | 11 | 09-13-2007 11:00 AM |
| Polyester resin problems. | zoso | Wooden Boat Building and Restoration | 9 | 10-18-2006 09:39 PM |
| Polyester resin | roko | Fiberglass and Composite Boat Building | 10 | 11-28-2005 08:39 AM |
