Old 01-12-2011, 01:25 PM
Edmundo Souto Edmundo Souto is offline
Rep: 37 Posts: 12
Any size infusion
As I promissed
Pictures of a 65 foot cat we Infused in kevlar + epoxi
half way
finished
Nice job.
Old 01-14-2011, 09:26 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Nice job indeed, well done!
Old 02-09-2011, 12:17 AM
jiggerpro jiggerpro is offline
Rep: 98 Posts: 135
Obviously he is another one of the "fishbone" fan club ........... or in this case if he does not open all at once it would be a double sequential fishbone .........
Old 02-09-2011, 01:34 AM
Herman's Avatar
Resininfusion.info
You cannot see how he did the sides, timewise. Probably sequential.
In the centre there is a vacuumline in a pleat, probably only connected with peelply, or wrapped in Airtech "Dahltexx" material. (allows air to pass, but no resin)
Old 02-09-2011, 01:56 PM
Rep: 37 Posts: 12
Sequence
First we openned the two lines from the keels to the sides.
Second when the resin reaches the tunnel lines I opened it.
There is a vaccum line on the top tunnel. We call it, a "Tail", made from fiberglass fabric 300mm height with the vac at the edge, with full length of the top tunnel.
Att Edmundo
Old 02-10-2011, 12:43 AM
Rep: 98 Posts: 135
Hi Edmundo, why did you use this approach to get a vaccuum line at the top of the tunnel instaed of the easier and more normal way of using just a spiral cut hose wrapped in peel ply ??
By the way, congratulations for the achievement which undoubtly is to master infusion up to the level shown in your pics ......... Hopefully I will join the club one day thank you for sharing with us ..
Old 02-10-2011, 05:14 AM
Rep: 37 Posts: 12
Tail use
The first rule in any infusion is to avoid the resin going to the vac line.
We have core at the top tunnel.
If you put the spiral on the core, the grooves will allow the resin going straight into the vac lines.
Then I usually make a tail like this, to "brake" the resin .
[IMG][/IMG]
Att ED
Old 02-10-2011, 12:59 PM
Rep: 98 Posts: 135
I see .........
infusion Aldric Comeau Fiberglass and Composite Boat Building 12 11-07-2010 07:35 AM
Infusion Help needed ( jestah Fiberglass and Composite Boat Building 5 06-05-2007 10:57 AM
What happens if I increase the size of the boat by 30% than the intented size abrahamg Boat Design 6 04-26-2005 06:09 PM
infusion pdesign Materials 1 08-18-2004 09:41 AM
Vacuum Infusion Wf benadeline Fiberglass and Composite Boat Building 1 05-07-2004 09:10 AM
