Old 06-16-2009, 10:08 PM
BIFFTHESKIFF BIFFTHESKIFF is offline
Alternative to Fiberglass and Epoxy?
Hello, I have been trying to think of other materials I can use to fortify the bottom of small rowboat projects. I have the epoxy, but I do not want to spend the money to "glass" the entire hull. Are there any other materials I can use with epoxy on the hull? I have heard bed sheets might work. I also have a large supply of Dacron left over from a Geodesic project. Will that work? I basically just need something that will bond with the epoxy as the boats will be painted anyway. Any ideas or comments? Thanks.
Biff
Old 06-17-2009, 12:23 AM
Rep: 2891 Posts: 8,792
I'm not sure what you mean by "fortify" the bottom, but a light 'glass sheathing will not make it stronger, but will improve waterproofing and especially abrasion resistance.
You can use most anything as a sheathing, but the trick is to match the elasticity of the resin with the fabric you use. "Glass works very well for this and frankly isn't particularly costly. I'm getting 8 ounce fabric at about 5 bucks a yard. You'll pay that down at the local fabric store (where your wife gets material) for cotton.
What is your goal for this boat?
Old 06-17-2009, 12:33 AM
Rep: 527 Posts: 792
Dacron is totally out of the question. We use Dacron as a release material (peel-ply) because no resin will adhere to it. It is good as a release ply, though.
Jimbo
Old 06-25-2009, 04:58 PM
tunnels tunnels is offline
old one !
Rep: 353 Posts: 1,515
Biff
You need you bumps feeling mate . why are you wasting you time doing a slap dash crap job and possible having to do it again sometime in the future at double the cost . You are a nut case !!
Do it properly, do it once and forget it ! simple !!
Old 06-25-2009, 11:52 PM
Rich M Rich M is offline
Rep: 10 Posts: 23
I love the nut case comment.
Not everyone wants to do things the way "everyone else" does. Let the man work.
I don't have any comments - I build plywood and polyester resin/cloth boats.
Old 06-25-2009, 11:58 PM
old one !
sorry i spend my life recently travelling to differant countries teaching people to do fibreglassing and ironing out problems that are really not probelms just people these days ask questions with out thinking and never use there brains first because if they did i wouldnt need to deal with sillyness on such a grand scale !!
Old 06-25-2009, 11:59 PM
6 or 8 ounce fabric isn't very expensive and you wouldn't need much for a small row boat. Dynel is another option, which is about the same cost with 3 times the abrasion protection as regular cloth.
Old 06-28-2009, 11:19 PM
Rep: 10 Posts: 23
Tunnels,
I bet that you have forgotten more than I'll ever learn. It's fun to do things differently than others and succeed - it takes a lot more work and trial & error tho'.
Is it okay if I send you a private message?
R
Old 06-29-2009, 12:47 AM
old one !
Originally Posted by Rich M View Post
Tunnels,
R
Hi any time ! stuartwrcom@gmail.com
Old 06-29-2009, 03:11 PM
Rep: 1397 Posts: 7,215
Using an old sheet will cost more in epoxy than 8oz would. Also, it will do a poor job and much heavier too.
Fiberglass Cloth or Fiberglass Mat? Fiberglass Resin or Epoxy Resin? canoe42 Fiberglass and Composite Boat Building 4 06-30-2008 09:18 AM
Cant use epoxy resin with fiberglass mat? willfishforbeer Materials 13 10-20-2006 02:35 PM
What kind of fiberglass/epoxy to use? KMD Wooden Boat Building and Restoration 15 11-02-2005 11:14 AM
Fiberglass with west epoxy over gelcoat? bhd Fiberglass and Composite Boat Building 2 03-04-2005 07:13 PM
CPES, Epoxy and Fiberglass Questions Guest Boatbuilding 4 09-04-2003 09:06 AM
