Old 03-06-2007, 12:16 PM
Anders Radmark Anders Radmark is offline
Rep: 10 Posts: 9
Airex Core
What is your experience of Airex cored hulls and deck? Boat from 1982. If Airex core under w.l. ? Is this o good core material.
Any experience in this experienced group
The Swede
Old 03-06-2007, 09:32 PM
jimslade jimslade is offline
Rep: 14 Posts: 304
There are better products to use now. airex is still a good product.
Old 03-06-2007, 09:44 PM
Rep: 505 Posts: 1,658
airex floats,and is stronger and lighter than fiberglass
Old 09-10-2007, 09:46 AM
patrik111 patrik111 is offline
Rep: 10 Posts: 41
Achievable radii
What is the smallest achievable radius possible for
ariex c70 60kg/m3 ?
What temperature is needed to do this?
What sort of radius is possible when the material is still at room temperature?
BR
Patrik
Patrik Elfving
Old 09-10-2007, 10:53 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
http://www.atlcomposites.com/product...alsa/index.htm
Sorry don't have time to research your question.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 09-10-2007, 09:09 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
Smallest radius....well it is simply a matter of cutting the material to thin slices and then relaminating it. The smallest radius is entirely up to you doing this. It is normal practice to laminate thin sheets to form even compound curves.
Airex PVC core foam using ? signum Fiberglass and Composite Boat Building 10 02-01-2009 04:26 PM
Airex foam core needed urgent BobDoe Materials 5 08-31-2006 04:56 PM
Airex foam core needed urgent (duplicate) BobDoe Fiberglass and Composite Boat Building 4 08-31-2006 04:42 PM
AIREX Foam core Brad Seger Materials 3 07-28-2004 01:36 PM
Baltek - AIREX R63 Foam Guest Materials 1 07-25-2003 10:14 AM
