Old 01-01-2006, 07:11 AM
rich99uk rich99uk is offline
Rep: 10 Posts: 43
Advice on Re gelcoating my boat
Hi can anyone one help I have osmasis really bad i started drilling it out however i came to the conclusions that i need to stip the gell coat off in order to dry the boat out which i am in the process of doing. I have the gelcoat two pack resin to re-do the boat however do i need anythink to coat the fiberglass first like a sealent or something before i start gelcoating or can i start gelcoating straight on to fiberglass once dried out
Thanks
Any advice is much appritiated
Old 01-01-2006, 10:05 AM
gasdok007 gasdok007 is offline
Rep: 10 Posts: 24
An epoxy barrier coat such as interprotect by interlux followed with bottom paint is the usual way to go. Why bother with gelcoat?
Old 01-01-2006, 10:27 AM
roob76 roob76 is offline
Rep: 10 Posts: 35
here is a good read on hull blisters
http://www.yachtsurvey.com/BlisterRepairFail.htm
Old 01-01-2006, 11:54 AM
Rep: 10 Posts: 43
reply
So can i confirm once i have taken back to Fiberglass I can just coat with a two pack epoxy resin a few times and then anti foul
Old 01-01-2006, 11:57 AM
GeoffSChapman GeoffSChapman is offline
Rep: 10 Posts: 37
Osmosis treatment
Have a look at this pdf
http://www.yachtpaint.com/Images/29_21595.pdf
This describes the phenomen and the treatment as offered from International, we treat 10-15 boats a year this way
Geoff
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Which Jacuzzi to install in my Boat? the big jetski Propulsion 4 12-14-2005 04:46 AM
fiberglassing plywood boat deck KMD Materials 11 11-10-2005 12:49 AM
Boat Stability help pls. trouty Boat Design 11 10-28-2005 11:55 PM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 11:08 AM
