| Advice on painting fiberglass boat I'm restoring a 1973 fiberglass boat, all of the sanding is done and it's ready to be painted. I'm thinking of using Interlux Fiberglass Bottomkote with Irgarol. How should I prep this hull for this paint? Besides the paint, what other products do I need to buy? Will this be the best paint for a fiberglass or is there something that might work better? Thanks. |
| I saw on another forum someone recomending the use of a barrier coat on the bottom then the bottom coat over that. Anyone know of an easy to use product for a first time do-it-yourself individual to apply this barrier coat? |
| I only use epoxy primer and urethane paint. |
| When ever I have painted a fiberglass boat I have used Awlgrip. I understand you are using a different system. The paint you use should have a system - other products that are compatible with the top coat. That is, there should be a recommended cleaner, de-greaser, final wipe, primer etc.... In the past I have used Interlux microplates for a barrier coat on bottoms. |
| Interlux No Sand Primer http://shop.torresen.com/ships_store...=YPA200Q&frm=g Are you sitting down? That price is for a quart! Check this out also. http://www.epoxyproducts.com/coaltar.html
| I painted my beach cat with Interlux brightsides this summer. I think it turned out pretty nice for a DIY job. |
| Spray Painting Fiberglass Boat?? | asianbandit | Fiberglass and Composite Boat Building | 6 | 11-03-2006 11:49 PM |
| painting a fiberglass boat questions | revshot | Fiberglass and Composite Boat Building | 3 | 02-12-2006 04:43 PM |
| Painting Fiberglass | Travis | Fiberglass and Composite Boat Building | 1 | 01-17-2006 10:49 PM |
| Painting Fiberglass | hunter | Fiberglass and Composite Boat Building | 1 | 08-31-2005 04:11 PM |
| Painting On Old Fiberglass (1956 Lone Star) | BINGOSIRLINGO | Materials | 3 | 06-28-2005 02:21 PM |
