Old 06-05-2009, 02:05 PM
kanaya kanaya is offline
advice on mending broken plastic seat on kayak
hi everyone im new here and defo need some good advice recently i bought an old sit in kayak pretty old the seat is plastic and needs bonded to what i believe is fibreglass as the seat is very much broken off can anyone suggest a really strong adhesive that may do the job ? all suggestions greatly welcomed (its my first kayak ) thankyou in advance
Old 06-05-2009, 02:36 PM
Ike's Avatar
Ike Ike is offline
Rep: 1256 Posts: 1,314
Use the seat as a mold and make a new one of fiberglass using epoxy resin. The epoxy won't stick to the plastic so when it has set up you can just peel it off.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 06-05-2009, 06:40 PM
Rep: 2891 Posts: 8,792
Oxidize the surface with a torch and use GFlex epoxy, from West System on the parts. This will bond fairly well, but unfortunately nothing really bonds well to those types of plastics. Log onto Westsystem.com and look in their user's guide for difficult bonding applications. With any luck they'll have updated the site to include the newer products and techniques.
Old 06-05-2009, 09:31 PM
oscarvan's Avatar
oscarvan oscarvan is offline
Rep: 10 Posts: 18
What type of plastic is it? Fiberglass? Polyethylene? A picture would help.
Out there, alone, there is only truth.
Old 06-05-2009, 11:00 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
Buy a new seat. It's the best long term solution. To fix a polyethelene seat will cost more (if your time is worth anything at all) and it won't have a lifespan as long as a new one.
That said, I've repaired polyethelene by welding it using a hot knife (my tile saw reservoir has lasted a year through a few tile jobs with no leaks yet).
Adding somw fresh plastic makes the joint thicker and stronger. Some could maybe be cut from the edge of the seat. You could heat it in a metal can on the stove (carefully, not too hot) and pour it into the fresh hot weld, or have a helper follow your hot knife as it melts a groove into the crack, pouring it in before the groove cools.
Tired And Broken... Sean Herron Open Discussion: All Things Boats & Boating 4 11-02-2008 10:22 PM
Tortured Plastic Kayak. alexlebrit Fiberglass and Composite Boat Building 8 05-14-2007 08:41 AM
Broken Screw Potterage Fiberglass and Composite Boat Building 0 09-23-2005 04:33 AM
Broken welds BWBasser Metal Boat Building 9 05-25-2005 01:04 AM
Recycled Plastic/Plastic Lumber Hulls for Pleasure Boats? Keith King Boat Design 8 09-29-2004 02:17 PM
